which 4.7L do I have - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 04-04-2012, 03:37 PM
gashauler's Avatar
gashauler gashauler is offline
Vehicle: 2008 dodge ram 1500 big horn
Color: blaze red
gashauler is on a distinguished road
Default which 4.7L do I have
The sticker on my door says it was built 06/08, my question is how can I find out which 4.7L do I have the 235hp or 310hp as the date is around the time they made the change from 07-08? The stealership said it was the 310 but the guy was kind of a DA, he opened the hood and looked at the CAI, is there a difference in size? I have nothing to compare it to.
Old 04-04-2012, 03:42 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
The clear give away would be that the new engine has 2 spark plugs per cylinder. The older engine had one per cylinder.
The new engine has one plug under the coil(intake manifold side) then off the same coil a plug wire goes over the valve cover to the second plug on the other side of the cylinder head(exhaust side).
That'd be a sure and easy way to find out.
Sean
Old 04-04-2012, 03:43 PM
snrusnak's Avatar
Rep:1388
Also, the newer engine has an electronically controlled throttle body, and the throttle body is plastic, not metal. The older engine had a metal throttle body and it was cable driven.
Another easy, clear way to determine what you have...
Sean
