Should I make the drive? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-04-2012, 03:45 PM
mikelken mikelken is offline
Vehicle: 1999 Dodge Ram 2500
Color: Metallic Red
mikelken is on a distinguished road
Default Should I make the drive?
A couple months ago I noticed a very small amount a coolant leaking from the water pump area. Since then there has been no more leaking and I've driven around 1500 - 2000 miles, plus a long weekend trip to Chicago (600 miles) with no leaking.
So here's my question....should I drive the truck from OH to CA without replacing the water pump (800 to 1000 miles a day for 3 to 4 days). Unfortunately, I have limited tools and area to replace it in OH, so I will have to pay a mechanic. Once I'm back in CA I can make the repair myself.
Thanks for your help!
Old 04-04-2012, 04:21 PM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500, 2001 Ram 1500
Color: 2500 White, 1500 Black
Rep:97
SnoopyIsMyHero will become famous soon enough
I wouldn't. Depending on where the leak is (gasket or around the bearing), you could find yourself trying to fix it on the side of the road or a very expensive tow and repair. The water pump isn't that bad of a repair, find a parking lot (Walmart?), some basic tools (1/2" drive socket set, screwdrivers, knife, gasket scraper) and a few hours of time. Oh, and replace the hoses and serp belt while you are at it.
2001 2500 5.9 4x4. Stock except for exhaust, step rails but I don't care, I love my beast
2001 1500 5.2 4x4. Stock except for exhaust, my new project.
Old 04-04-2012, 04:28 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
I would replace the pump, I wouldn't want to risk having it break down on a trip, having car problems during a trip is the worst because it will cost you money and give you nothing but a damned headache.
Old 04-05-2012, 12:05 PM
Color: Metallic Red
^^Thanks for the advice. Any ideas why the leak would have stopped?
Old 04-05-2012, 09:27 PM
ramvan2500's Avatar
Rep:141
It could have stopped from maybe some build up, I had a freeze plug that had holes in it but their was so much crap built up that it never leaked until I went to rebuild my transmission of course.
I would also say it could be the calm before the storm!
Old 04-13-2012, 03:49 PM
Color: Metallic Red
It turns out its the water pump is fine. Unfortunately, the timing chain cover gasket has some seepage on the passenger side. Being that this repair is a little more involved, do you guys think I can hold off making the repair right now?
I've read that this a very common problem with the 5.9s, but I'm not sure whether these leaks ever get past the seeping stage.
Thanks in advance!
Old 04-13-2012, 04:19 PM
ramvan2500's Avatar
Rep:141
Thanks in advance!
I would fix it right away because if coolant leaks into the timing chain cover then it would end up mixing with the oil and you will out up spending much more then 4 hours and 10 dollars for a timing chain cover gasket.
Old 04-13-2012, 04:21 PM
Rep:2929
If you want to be stress free, get it repaired now, replace the water pump at the same time, if it is over 5 years since it was last replaced
I am sort of adventurous i would carry a couple of gallon jugs of water with me
check your leak when you fill up each time with gas
check the radiator fluid level when ever the radiator is cool enough, like after a few hours of not driving
When i drove from Connecticut to San Diego
first day was from the start to Dayton Ohio
2nd day took me to Joplin, Missouri
3rd day i only drove 8 hours & i was west of Fort Worth
4th day i was in Lordsburg, N.M.
5th day i was in San Diego
Join AAA before you leave, personally i have the Premier Package, more Towing Miles
There is a lot of nothing between cities once you leave Ft. Worth, Tx.
Old 04-13-2012, 04:22 PM
Ohio Mossy Oak's Avatar
Ohio Mossy Oak Ohio Mossy Oak is offline
Vehicle: 1999 quad cab sport 4x4
Color: Black and rust/dents
Ohio Mossy Oak is on a distinguished road
Thanks in advance!
Im 40min east of Columbus OH,along I70...I have never done a timing chain cover gasket on these trucks(i see mine in my future though)..But i may be willing to lend a hand...Let me know,maybe we can get it worked out.I had a T type quick connect heater hose blow on my wife mini van..Only 40 min from home..I aint made of money to pay for tow etc...Got lucky an chopped the quick connect out an put a 5/8 T an hose clamps on it..I had my kids with me so that added to the stress..I cant imagine being 1500 mile away from home an dealing with it
AT THIS POINT MY REPAIR LIST IS LONGER THEN MY MODIFICATION LIST
Old 04-15-2012, 12:22 AM
Color: Metallic Red
Thanks a lot for the offer! If you were closer, I would definitely take you up on it. I'm still trying to decide what to do. I don't have much free time before the move, but I don't want to break down either.
