Trimmed my 2012 1500 4x2 Express today - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 04-04-2012, 08:33 PM
sumncguy sumncguy is offline
Vehicle: 2012 Ram Crew Cab Express 4x2
Rep:16
sumncguy is on a distinguished road
Default Trimmed my 2012 1500 4x2 Express today
I setup the WDH today to tow my travel trailer.
I did have to move the hitch head up a notch to make up a 2.5 inch difference of the last truck.
Prior to adjustment
The height from the ground to the edge of the rear wheel well was 38".
The height from the ground to the edge of the front wheel well was 37".
After adjustment
The height from the ground to the edge of the rear wheel well was 37".
The rear should be 37 1/2 " after the adjustment and fully setup ... but I can live with 1/2 inch.
I also needed a new brake controller. In my opinion the OEM is a total waste of money. I believe it is a time delayed controller. I bought a Tekonsha Prodigy P2 360 degree proportional controller for 100 bucks less than the OEM including the cable which took literally 3 minutes to install. Anyone who has towed with the proportional knows it out performs the time delayed hands down without question. Gonna test ride on Friday morning. The camper needs a repair so that will also be a good time for the CAT scale.
Old 04-05-2012, 07:18 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Glad you got it all set up. That minor adjustment is perfect for air bags to take up and solidify....
Regarding the controller, I used Only the Prodigy prior to this truck that came with it built in. The Prodigy is a great controller no doubt. If I didn't have the built in, I would do the same. BUT, the factory controller is absolutely better than the Prodigy IMO. Yes, it's on a new truck with new brakes etc., but if you adjust it in the EVIC properly, the response is fantastic. AND, IIRC, it ties the trailer brakes into the vehicle ABS..
~~ But in your situation, the Prodigy is a great choice
Old 04-06-2012, 11:25 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Looks great.....Nicely done......
Old 04-07-2012, 09:18 PM
Rep:16
Hey bikenut is the built in proportional ?
Old 04-08-2012, 09:05 AM
Bikenut's Avatar
Rep:73
The way I understand Proportional is that the more you apply the trucks brakes, the more the controller applies to the trailer. So, Yes it is. you can see it in the EVIC. You have to set the controller for the type of trailer you have and then you can adjust the 'gain'. There is even a setting for Light or Heavy.
On a side note: The factory controller in the RAM is WAY better than the factory controller in the Super Duty
