Old 04-05-2012, 10:10 PM
blackoutdodge's Avatar
blackoutdodge blackoutdodge is offline
Vehicle: 2001 dodge ram 1500
Trim Level: sport
blackoutdodge is on a distinguished road
nope. nothing at all.. and ive been starting it once a week and lettn it run for about 10 min each week to keep battery fine and everything fresh.. but battery died anywho.. lol but it was hooked up to another truck while i was trying to start it today..
Old 04-05-2012, 10:13 PM
Trim Level: sport
nope nothing at all.. and id start it every week to keep her healthy
Old 04-05-2012, 10:19 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Well I have a similar issue but it is actually intermittent, try to shift the transmission into neutral and then start it. If you can't get it out of park then assuming the driveshaft is connected, rock the vehicle back and forth while trying to shift it into neutral. Sometimes I have to rock my vehicle into park lol
Old 04-05-2012, 10:30 PM
Trim Level: sport
transfer case is not on truck cant other wise would have tried :/
Old 04-05-2012, 10:35 PM
ramvan2500's Avatar
Rep:141
then you're going to have to set the parking brake and go under the truck with some pliers and rotate the output shaft while trying to shift the shift lever on the transmission, disconnect the cable from the lever then when you shift it out go back into the truck put the key in the ignition put it to the on position and then shift the lever in the truck and then back under the truck reconnect the cable then out from under the truck shift into neutral then try to start. sounds complicated but it's full of exercise, any problems im here
Old 04-05-2012, 10:57 PM
Trim Level: sport
im not gonna be able to get back under it till tomorrow though i appreciate the help though. cause im lost as all hell on why this wont move
