Old 04-05-2012, 11:00 PM
TXBOI1982's Avatar
TXBOI1982 TXBOI1982 is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT Thunder Road
TXBOI1982 is on a distinguished road
Cool Best way to lower my '05 1500 4dr?
Hey I want to lower my '05 1500 4dr SLT but I want to do it right with as few problems as possible. I've got a guy trying to talk me into a BellTech 2"-5" drop kit with the front spring/shock and rear flip kit. I want it to be as level as possible, I definitely do not want the rear lower than the front and I don't want it to ride like a tank. I've got 22" rims all the way around with super hard street tires and hate that I can feel every bump in the road already, I dont want it to get any worse. I just rolled over 100,000 miles with no suspension work done at all so I need to get it done asap. Also, should I get the optional BellTech rear swaybar? Please Help. Thanks Everyone.
Cheers - Charles
Old 04-05-2012, 11:12 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
it will still ride the same with the drop but better shocks may provide some assistance as well as your sidewall ratio.
Drop + rear sway bar will make a big difference in cornering.
inspect your perches and weld if needed.
Old 04-06-2012, 12:07 AM
I push the skinny pedal
Rep:3277
I'll assume a 2wd, and if it's the case, the belltech will be fine. I'm a fan of McGaughy's kit, but you may want to consider 3/5 as the 2/5 may put the rear lower. The rear sway bar will make a difference in the body roll around corners, but it will cause you to slide around a bit more on the seat.
I would highly recommend swapping your shocks, the stock shocks are horrible and mine were seeping oil. After my shock swap the ride was night and day different, even with my 22s with 40 series rubber.
Kurtis
Old 04-06-2012, 05:30 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
It is impossible to drop an 05 4dr...dont even try.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
