Question about max performance upgrades - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 04-06-2012, 02:20 AM
P-Rez's Avatar
P-Rez P-Rez is offline
Rep:28
P-Rez is on a distinguished road
Default Question about max performance upgrades
I always read ppl saying dont get that unless your doing head work, etc. Like for instance id like to get the 90mm TB and progressively down the line upgrade to those things, is it a problem to do those things? like id like to get the arh 1 7/8 instead of 3/4 but ppl say they dont get those because they arent doing cam work. I jus twant to know if theyre are any issues with such installations. thanks
P-Rez
Old 04-06-2012, 05:39 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
You need the supporting mods to see the full potential (or in some cases any potential) of the main mod in question.
As an example, exhaust systems. If you have 2" stock piping and you just replace the muffler with a 3" one while leaving the 2" piping. It will still work, you probably wont notice anything as far as gains until you replace the piping with 3" to match the muffler and to allow for more flow (assuming that you can utilize the larger diameter).
Or replacing your cam with one that has more lift and duration but not replacing your valve springs. You could probably run it, but you would never be able to see it's potential until the springs are replaced so you don't float a valve.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
