Old 04-06-2012, 04:25 PM
Matt Tastic's Avatar
Matt Tastic Matt Tastic is offline
Vehicle: 2008 Dodge Ram 1500 5.7 Hemi
Color: Yellow
Matt Tastic is on a distinguished road
Send a message via MSN to Matt Tastic
Default 08 1500 cc rca adaptor help???
Ok...I want to Keep factory radio and want to add amp for sub and figure I want to tap into rear speaker wires for rca converter. Is it easier to tie in behind radio and run wires to under front seat or from incoming wires by the back doors? Thanks for the help all that respond!!!
Old 04-06-2012, 10:23 PM
itsahemi4x4 itsahemi4x4 is offline
itsahemi4x4 is on a distinguished road
If you have the Infinity system, tap the front door speakers. They get the bass signal from the Infinity amp. The wires are behind the kick panel. If you need a line level converter with a built in volume knob, let me know. I've go one I'll part with pretty cheap. Only used for three weeks. Upgraded entire system and no longer need it.
Old 04-06-2012, 10:31 PM
Color: Yellow
No infinity=stock plain jane!! Just need easiest way to tie in my line level converter i have to stock speaker wires...Either from behind stereo or if i have to tap both rear speakers-Thanx for helpin man!!
Old 04-07-2012, 12:18 PM
I'd tap both sides. Only tapping one will not give you the full stereo signal. You shoould be able to tap them behind the radio if u don't have the infinity. Not sure what colors, but I think theres a diagram on here as to what colors are what. Make sure you have a volume control for the amp though. It helps a lot, especially if you listen to different styles of music.
