Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-06-2012, 05:25 PM
bronort's Avatar
bronort bronort is offline
Vehicle: 1988 Dodge D100
Trim Level: base
Engine: 1988-1991 239ci (3.9L) LA V6 125hp
bronort is on a distinguished road
Default 88 3.9 water pump installation help
I have removed the waterpump properly and the problem is the install. Any thoughts or helpfull advice to make the install easier. Just frustrated wanted seek some good advice.
Old 11-06-2012, 09:11 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
If you have it apart just clean the block and insure any old gasket materal is removed. But while you have the system drained down it is a good time to check belts and any hoses and replace them rather be caught on the road broke down. usually in the middle of a storm in the middle of knowhere. I also like to put antiseize on any bolts I loosen or remove.
