Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 04-07-2012, 05:27 PM
Miami Son Miami Son is offline
Vehicle: 2012 Ram 1500 Sport Crew Cab
Color: Mineral Gray
Rep:26
Miami Son is on a distinguished road
Default Tonneau cover lighting
I did this on my 2000 Ram and just had to do it again for the new beast. The install is pretty easy, but time consuming and requires some soldering skills, and electric drill and some hand tools. Total spent for this mod was about $65 for the lights, connectors and wiring supplies. Total time was about 4.5 hours.
These are the lights I purchased from an eBay seller in Hong Kong. Took about 8 days to arrive. The nice thing is these are encapsulated in clear silicone to make them waterproof and they have 3M adhesive on the back. The roll is about 15' long, but I only needed three 3' pieces for this project. The rest will find other uses.
I always mount an accessory receptacle in the back corner of my trucks. Makes it easy to connect a 12v compressor, vacuum or other 12v device when working away from the interior. This one is made by Bell and can be panel mounted for a clean look. Also has a rubber cover to keep the elements out. It cost $9.95 at Autozone.
I made this harness for the 3 light strips that are mounted to the bows from my cover. The connectors are Radio Shack items while the corrugated sheathing and anchors came from Advance Auto. This gives the harness a clean, factory look and allows quick disconnection for whenever I need to take off the cover and remove the bows to load something in the bed.
Close-up of a connector.
The plug to power everything is a standard cigarette lighter-type plug. I connected the socket to the running light of the left taillight assembly. I prefer this to having it be hot all the time so that anything plugged into it can't be left on inadvertently.
The lights off.
The lights on. You can't tell because there's a lot of ambient light, but in the dark they really light up the bed. Makes finding things back there at night a lot easier.
Old 04-07-2012, 05:43 PM
Rep:3322
Very move, I like the disconnects at each rib, though I would have hardwired them into the 12V circuit and left the recepticle free for your accessories. Never know when you will need to use that compressor in the dark and then that light will be your best friend.
Old 04-07-2012, 05:46 PM
Color: Mineral Gray
Rep:26
I carry one of these if I need to do that.
http://www.ebay.com/itm/Dual-Car-Cha...item2a1bd2ae5c
Old 04-07-2012, 06:20 PM
Rep:3322
Smart azz, have an answer to everything, don't ya
Old 04-07-2012, 06:50 PM
itshertruck's Avatar
itshertruck itshertruck is offline
Vehicle: 2016 Dodge Ram 1500 CC
Trim Level: Rebel
Rep:15
itshertruck is on a distinguished road
Send a message via AIM to itshertruck
You asked, and he answered. You left the potential for a smart azz comment to be sent your way... I like the install. Very clean!
If it's too loud, You're too old!!
Dodge the father and RAM the daughter!!!
Old 04-08-2012, 08:58 AM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Nice Job! :smile up: So you only have power when the trucks running lights are on?
Old 04-08-2012, 09:25 AM
Color: Mineral Gray
Rep:26
Thanks. Yes, only when the parking lights are on. I could have wired it with a switch to an always-on hot feed, but then I'd have to remember to turn the switch off or the socket will be on all the time. If I forget and leave the lights plugged in (or some other accessory) they will go off when I turn off the truck lights. Don't want anything plugged into that socket to be draining my battery when it shouldn't.
Old 04-08-2012, 09:32 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1648
That looks sweet......Nicely done.....
Old 04-08-2012, 11:28 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
very nice work. I like the clean install.
I did something similar but mine is fixed and and it has the option for accent lighting for the nights at the drive-in or white light for when i need to see. I have two relays mounted under the hood. One for the red and one for the white. the red ones have a switch mounted in the cab that activates the relay then one hot wire runs to the bed to the lights. the white ones also run off a relay but the switch is actually the cargo lamp switch.
Old 04-09-2012, 11:49 AM
Bikenut's Avatar
Rep:73
There's a body in your bed!
