Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 04-07-2012, 06:41 PM
mikek's Avatar
mikek mikek is offline
Vehicle: 2013 Ram
Color: Deep Cherry Red
Rep:16
mikek is on a distinguished road
Default o2 sensor not ready, catalist not ready, WTF
I went to get my 40000mi new to me truck inspected today and it fails inspection because the o2 sensor and catalist is showing not ready. This will usually happen when either the battery has been disconected or a trouble code has been recently cleared, but after you drive for 50 or so miles everything should be ready again, I have had this truck for a month and have put 1100mi on it since. I have not disconnected the battery and today after the failed insp. was the first time a scanner has been connected to it, there are no codes showing anywhere, the cat is reading the correct temp. and the o2 sensor is showing the right reading, anyone ever see this? sounds alot like a bad computer.
Old 04-08-2012, 04:06 PM
CARROLLX42's Avatar
CARROLLX42 CARROLLX42 is offline
Vehicle: 2004 dodge ram
Trim Level: Hemi Sport
CARROLLX42 is on a distinguished road
Readiness codes are a pain in the a$$. At work when I put it on the emissions machine and readiness codes aren't set. Here is what I do. I get the car going about 60 mph on a straightaway. Then just put the car in 1st gear and it will start down shifting and eventually get down into first. It works 9 out of 10 times.
SUPPORT YOUR LOCAL 16's
MC means club not gang.
Old 04-08-2012, 09:01 PM
mikek's Avatar
Vehicle: 2013 Ram
Rep:16
Seriously, or are you just playing with the new guy? Is it really possible that after a month and 1100 miles it still not ready?
Old 04-12-2012, 09:19 PM
mikek's Avatar
Vehicle: 2013 Ram
Rep:16
Mechanic friend of mine said he has had to change a few t-stats because they stick in the open position and the engine never comes up to operating temp. I replaced it today and I will have to put some drive cycles on it and see what happens.
