ATI underdrive pulley/super damper fits 2008+ 4.7L - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 04-07-2012, 09:41 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Default ATI underdrive pulley/super damper fits 2008+ 4.7L
Thanks to member darknight for trying this mod out. He confirmed that this ATI underdrive pulley/super damper fits and works on these trucks. He said the truck feels "lighter" with the underive pulley as well. And we don't need to mention how good ATI dampers are, I'm sure he just added life to his engine.
Just wanted to share the good news
Sean
Old 04-08-2012, 01:48 PM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
I'll be posting some pics!
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 04-08-2012, 11:01 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
I just ordered mine. How is the install guys? Difficult?
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 04-09-2012, 09:13 AM
snrusnak's Avatar
Rep:1388
You need a special removal and install tool from what I understand. Nick at airram will rent/loan you the tool for 1 week for a small fee, IIRC it's like $15 + shipping, so ~$25 or so. Then he charges additional for each day after 1 week if you have it that long.
Sean
Old 04-09-2012, 09:30 AM
Color: Gloss Black
Rep:141
The install went pretty quick compared to what i was thinkin it was going to be. Remove the fan shroud for sure. Then remove the stock belt and get to work on removing the stock pulley and damper. I put my truck on ramps that helped a whole lot. Then once its off put the damper on and torque it to specs. Then the pulley and also torque it to specs. then you are basically done. Put the new belt on and turn her over to make sure everything runs good.
It would be best to use a impact gun if you have one. I had to use a breaker bar and wedge a pipe wrench at an angle to lock the pulley in place to break that center bolt. The impact did the rest of the work. Then you use the puller to bring the pulley out. you can only use the impact to a certain point before the back end hits the radiator. At that point i used a ratchet to do the rest of the pulling using the puller tool.
Quick tip: (if you use the puller from air ram it comes with two rods. Those rods are NOT long enough. You have to put the center bolt back in and use the stud from the puller tool to push off of that. Then once the stud bottoms out just remove the tool then loosen the center bolt to raise it up and put the puller back on and do it again till its completely off.)
Then install the damper pretty simple. Just follow the instructions it comes with since you have to use the specs when torquing the new pully/damper. Get the correct belt diagram and put the belt back on.
Useful Tip: (Take a picture of your stock belt setup before removing so you can go back and reference when installing the new belt.)
Old 04-09-2012, 09:42 AM
snrusnak's Avatar
Rep:1388
^what belt did you use?
Sean
Old 04-09-2012, 12:15 PM
Color: Gloss Black
Rep:141
The one provided from the website.
The stock one was WAY longer lol.
Went to o 'Riely's and bought an in-house brand. MasterPro i believe was the name of the brand.
Old 04-09-2012, 12:26 PM
Color: Gloss Black
Rep:141
Old 04-09-2012, 12:33 PM
snrusnak's Avatar
Rep:1388
Just to sum up everything for this pulley:
All the parts needed to do this job(except the belt I think) can be bought at airram. The damper and pulley(they have 4 configurations) and the installation/removal tools(can be rented as well).
The belt they recommend for the under drive is Goodyear 4060855 Gatorback Poly V-Belt and can be found at your local part store.
They have a 6" and a 7" damper, along with a stock diameter pulley and a 25% under drive pulley. Both pulleys can mount to both dampers. They say the 7" damper is recommended for 7,500rpm or above(so probably almost nobody).
They also have an alternator pulley kit if needed. Made by MSD.
Luis, I didn't actually do the work and you did, so if I missed anything fill in the blanks
Sean
Old 04-09-2012, 12:51 PM
Color: Gloss Black
Rep:141
Ya the 7" damper is more used on a supercharged engine is what nick from airram informed me on. My stock alternator pulley seems to work just fine. All electronics ect. seem to be working normal. If your local parts store doesnt carry the Goodyear 4060855 Gatorback Poly V-Belt they are able to convert the part number onto another brand and get you what you need. So dont get discouraged when they say they dont carry goodyear (My O Riely store didnt carry goodyear).
