Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 04-09-2012, 06:03 PM
Ramtronic Ramtronic is offline
Trim Level: SLT Big Horn
Color: Deep Water Blue Pearl
Ramtronic is on a distinguished road
I don't suppose you had a chance to see if the filter was actually loose or not. Last time I had my oil changed at the dealer I had to tighten the drain plug from the oil pan to stop it from dripping!
Old 04-09-2012, 09:40 PM
124rr88 124rr88 is offline
Vehicle: 2010 Ram TRX4
Trim Level: TRX4
124rr88 is on a distinguished road
I change my own oil and found the same issue with a mopar filter last change, it was on correctly so??? I replaced it with a NAPA Gold.
Old 04-10-2012, 12:09 AM
wickedpissahtruck's Avatar
wickedpissahtruck wickedpissahtruck is offline
Vehicle: 2014 Ram Laramie 4x4
Color: Maximum Steel Metallic 2 tone
Rep:23
wickedpissahtruck is on a distinguished road
I doubt it was a faulty filter. Remember who is doing the oil changes at the dealerships. Mostly kids out of high school or low man on totem pole and I'm sure their hand tight is a lot different than most of us on this forum. I very rarely have oil changes done anywhere but my driveway, but on the couple of rare occasions where I have had to take it to dealership something was always loose. Either filter itself or drain plug.
Old 04-12-2012, 02:29 AM
thewagon thewagon is offline
Vehicle: 2010 RAM 1500 QC BigHorn
Rep:35
thewagon is on a distinguished road
The oil change area is the express oil change area and all customers can watch the entire process. The tech is an older gentleman (lower 50's).
I will continue to monitor the oil change for any further leaks (just had it changed last week).
Yes, I do all my oil changes on all my cars. Still doing it on my 2005 Magnum.
The RAM has a 3 yr free scheduled services which is why I am having the dealer do them.
My Magnum had the same 3 yr scheduled service and had absolutely no issues.
Thanks for all the replies and suggestions
Andrew
Old 04-12-2012, 08:13 AM
MeanMango2010's Avatar
MeanMango2010 MeanMango2010 is offline
Vehicle: 2010 Ram 1500
Color: Mango Tango
Rep:59
MeanMango2010 will become famous soon enough
I've seen filters leak from over tightening twice now. I work at a Firestone and the one guy we had working there always put his filters back on with the same tool he used to remove it. Twice he has had a nice steady flow of oil through the parking lot. For some reason I am always the guy who fixes screw ups. Upon checking it out the filters were on super tight and I all but had to crush it to remove it. Coincidentally the one was actually on a 3rd gen Hemi, the other on an F150. The only theory I can offer on this is the gasket gets so squished it pushes out slightly or something.
Vortec Supercharger, Upgraded Trans by MGH w/ Edge 2800 stall converter, Yukon DuraGrip LSD, ARH LongTube Headers, 18" Mufflex and QTP Cutout, AIS Water/Meth, 2/4" Ground Force, E-Fan w/ clutch fan delete, random orange and black paint.
Old 04-12-2012, 06:45 PM
Leatherman2010 Leatherman2010 is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Leatherman2010 is on a distinguished road
Default Leaky Filter
Mopar service filter is produced by Purolator, a double gasket would blow out immediately. Filter was probably not tightened enough during installation.
Old 04-13-2012, 05:58 PM
Holleywud's Avatar
Holleywud Holleywud is offline
Color: Austin Tan Pearl
Holleywud is on a distinguished road
It's also common for people to overlook cleaning the mounting surface where the filter goes. Applying a some clean oil to the gasket prior to installing the filter helps too. I see a lot of rookie mistakes at the dealership where I work. Just because the guy at the quick-lube is in his 50's doesn't mean he gives a damn.....
Old 04-14-2012, 01:09 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
Double gasket would be my first guess also
My '09 doesn't drip a drop, but i use a quality oil filter, WIX
Who makes the MOPAR filter is a toss up, might even be a Fram for all anyone knows
we do know that the oil at the dealership is a Shell oil product, PENNZOIL
All the ones Ive looked at appear to be built by Purolator and have a similar thread end bypass as the FL820S Motorcraft (That also fits our trucks). However they are not the same and dont even share many parts. The base plate for instance is a completely different design.
The oil in both bulk (assuming the dealer participates in the Mopar Oil Purchase Program) and bottle form is "Shell's Premium Conventional" aka Pennzoil Yellow Bottle.
Gene
Old 04-14-2012, 03:01 AM
The Misfit's Avatar
The Misfit The Misfit is offline
Vehicle: 99 Dakota R/T
The Misfit is on a distinguished road
Kinda sounds like it has double gasket, or maybe it's loose, hopefully it's not cross threaded..
I use K&N filters, never had a problem, this of course is on a 5.9 Mag..
Old 04-18-2012, 01:59 PM
dkerr24 dkerr24 is offline
Vehicle: 2011 Dodge Ram
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
+1 for another Ram owner using a Motorcraft FL-820s oil filter on his truck. Same filter as used on my wife's 2006 Ford Escape, so buying oil filters is easy to remember what to buy.
Darin
