A/C/ Evaporator Core and Heater Core - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-08-2012, 08:36 AM
voisineka voisineka is offline
Vehicle: 2000 Dodge Ram
voisineka is on a distinguished road
Default A/C/ Evaporator Core and Heater Core
Anyone see any problems with these pictures?! I pulled the a/c evaporator core and heater core yesterday and this is what I found. I am completely amazed at how much crap had made it's way to the evaporator. And I am almost equally amazed at how nasty the heater core is. I replaced them both with new cores and will be putting the dash back together today.
Not a particularly fun project, but it is always interesting to take things apart and see how they work!
voisineka
2000 Dodge Ram 1500 5.9L Laramie SLT
Old 04-11-2012, 10:58 PM
Looey's Avatar
Looey Looey is offline
Vehicle: 1996 Dodge Ram 3500
Trim Level: SLT Laramie
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Looey is on a distinguished road
what a mess....how long did it take you to remove the a/c evap and heater core?
I have to do the same to my '96. Doesn't look like any fun at all.
Old 04-13-2012, 08:59 AM
Looey, I had the luxury of having my dash already in pieces from cracking, so I didn't need to spend much time being careful while I removed the dash plastic (I ended up replacing it). In all, it took me about 13 and a half hours. That included two trips to Napa, messing around for about an hour trying to drain the coolant from the engine (which I ended up not doing). My Haynes book said th drain the coolant, but it was not necessary - just have some rags available when you pull the radiator hoses and pull the housing from the interior. Also, I would plan on simply replacing the radiator hoses that connect to the heater core. I tried to pull them off, but ended up cutting them off. The cost to replace them is minimal and it saves time!
I HIGHLY recommend taking pictures along the way. I referred to them MANY times when I was putting things back together.
The other thing is that I had the a/c discharged ($85) prior to working on anything and then recharged ($175) once everything was back together. I hadn't quite expected that much of a cost, but it's something to think about.
Overall, it was a fun project since I have never done anything this involved in a vehicle before and it was interesting to see all of the parts and figure out what they do.
Good luck with yours and if you have any other questions about my experience just let me know!
voisineka
