towing capacity - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-08-2012, 04:19 PM
Outdoorsman1500 Outdoorsman1500 is offline
Vehicle: 2011 Dodge Ram 1500 Outdoorsma
Trim Level: Outdoorsman
Outdoorsman1500 is on a distinguished road
Exclamation towing capacity
I own a 2011 Dodge Ram 1500 Outdoorsman and I was wondering if anyone knew the towing capacity on it. also where i could pick up a nice cattle guard without breaking the bank
thanks
Old 04-08-2012, 04:38 PM
Ramitupyour Ramitupyour is offline
Vehicle: 2011 dodge ram sport
Color: Flame red
Ramitupyour is on a distinguished road
10,500 lbs advertised for the 1500's
Old 04-08-2012, 04:59 PM
mmcglynn264's Avatar
mmcglynn264 mmcglynn264 is offline
Vehicle: 2011 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
mmcglynn264 is on a distinguished road
check here: http://www.rambodybuilder.com/2011/d...ammlup1500.pdf
find your truck on the chart, it will list max trailer weight
[B]RetraxPro tonneau cover; Mopar Power Tailgate Actuator; CoverKing NEOSUPREME RED w/BLACK SIDES; AMP Reasearch Powerstep; Mopar Molded Splash Guards; Husky WeatherBeater Floor Liners[/B]
Old 04-08-2012, 05:29 PM
Rep:2929
a lot depends on the rear end ratio & engine size
is yours a 4X4 ?
these are your options, it is for a crew cab
http://www.rv.net/sharedCode/ford/in...mit=&x=76&y=17
2009 DODGE RAM_1500 1500 CREW SLT, CREW CAB, 4WD, 5-Spd Automatic 545RFE Transmission, 5.7L V8 HEMI MDS VVT Engine:
With 3.92 Axle Ratio Axle Ratio [i] You Can Tow 8500 lbs
Gross Vehicle Weight Rating (GVWR) [i] = 6800 lbs
Payload [i] = 1455 lbs
Curb Weight [i] = 5345 lbs
Curb Weight Front/Rear = 3079 lbs/3079 lbs
GAWR Front/Rear [i] = 3900 lbs/3900 lbs
Gross Combination Weight Rating (GCWR) [i] = 14000 lbs
capacity, dodge, outdoorsman, ram, towing
