Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
tonneaucovered.com
Old 04-09-2012, 03:36 AM
BurningBlue's Avatar
BurningBlue BurningBlue is offline
Vehicle: 2003 4.7 QC Ram
Color: Graphite Metallic
BurningBlue is on a distinguished road
Default Idle stumbling issue...help
I am getting a strange problem. My Ram is suffering from random fits of low RPM stumble, that usually only presents itself while stopped or at very slow speeds. I never have any symptoms during normal driving...sometimes it will stall out though at a stop light or bounce from 800-2000 RPM.
It is very random, sometimes doesn't happen at all during an entire driving session. When it does happen, it doesn't matter whether the engine has warmed up or if I just started up the engine, it usually doesn't last very long...maybe 20-30 seconds. The headlights and console lights dim & brighten with the idle bouncing back and forth. Also I get no codes thrown...completely stock engine 66k miles. No leaks
Any idea what my problem could be? Just ran a whole bottle of Seafoam in the fuel tank, and it didn't help.
2003 Ram 1500 4.7L Quadcab
1998 "Nassy Blue" Corvette LS2 6spd - 450 RWHP
Old 04-09-2012, 02:30 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
I just had the same problem start checking your fuel pressure while you drive that's how I found out. everything at idle looks normal but when i hit that gas pedal the stumble begun. Mine was the fuel pump
Old 04-09-2012, 09:47 PM
Trock03 Trock03 is offline
Vehicle: 2015 Ram 1500 4x4
Color: Maximum Steel
Trock03 is on a distinguished road
Another thing to look at is your idle air control and throttle position sensors. The rpm fluctuation is pretty common with our trucks. I replaced both at the same time because it's a cheap and easy job so I can't say for sure which fixed the problem. All I know is my truck runs like a champ now.
Charlie don't surf!!
Old 04-10-2012, 10:05 AM
would it still fluctuate the idle during open loop.....if one of those were going out?
