Old 04-09-2012, 02:12 PM
green ram green ram is offline
Vehicle: 2011 Dodge Ram
Color: Green
green ram is on a distinguished road
Default integrated brake controller
I have a 2011 2500 Ram diesel, pull a 35 ft. Montana 5th wheel. Only got to pull Montana once to winter storage area since I got my new Ram.
My problem is the factory integrated brake controller only works with the manual slide lever, when applying the foot brake nothing happens. I tried setting the gain up to 8.8,trailer brakes lock up with manual, still nothing using brake peddle. From what I've read on internet, it's a hydraulic over electric problem. Anyone out there have this problem? Any fix? I do have a Prodigy P2 brake controller from my f-250 I could install but I've read the dealer will have to disconnect the ITBM before it will work.
Old 04-09-2012, 03:45 PM
h2oman's Avatar
h2oman h2oman is online now
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:329
Maybe you could switch from light electric to heavy electric on your EVIC. I honestly don't know if that will help but it is worth a try.
333Half the beast
I used to be
Old 04-10-2012, 05:00 PM
Color: Green
Default integrated brake contoller
Dealer said they just had a truck in with same problem. Said they re-flashed the system (what ever that is ) and now owner says it works. So I guess I will bring it in and see.
Old 04-10-2012, 10:11 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Ya verify settings in your EVIC first. GL
