Old 04-09-2012, 09:50 PM
wilky70 wilky70 is offline
Vehicle: 2011 Dodge Ram
wilky70 is on a distinguished road
Default T/C question
After waiting for more then 2 months the dealer finally got my replacement torque convertor in. I had been calling every 2-3 weeks for an update and they told me they were waiting for a new part number to issued that would address the problems Dodge has been having with our trucks.
I dropped the truck off tonight and asked what part number convertor they were installing in my truck, He told me R8051146AB and said the "R" meant re-manufactured.
Does this seem correct? has Dodge issued a new part number and are the parts re-manufactured?
Old 04-09-2012, 11:15 PM
roar84 roar84 is offline
Vehicle: 2011 Dodge Ram Crew 4X4
Trim Level: SLT Big Horn
Color: Mineral Gray Met.
roar84 is on a distinguished road
Not sure on the numbers or the re-manufacture. When I had mine replaced in Feb. of this year the service advisor told me it was a new converter that they were going to put in. I checked my service paperwork from when I had mine replaced and it had the following information:
Installed RL051146AB : Converter: Torque Qty:1
Core Chg UL051146AB: REM: Converter Kit: Core Char Qty: 1
I hope this infomation helps. You have me wondering if I also got a re-manufactured converter.
Old 04-09-2012, 11:43 PM
readster1's Avatar
Vehicle: 2011 dodge ram
Trim Level: Long horn/sport
Color: brilliant black pearl
Rep:12
I keep hearing about tc recalls how do I find out more about this issue I have a 2011 sport/long horn and was wondering how do I find out more about this??
Old 04-10-2012, 01:56 PM
Rammin88 Rammin88 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:20
Rammin88 is on a distinguished road
I had the TC issue. They replaced mine with a re-manufactured one. To be honest, I'd rather have a re-manufactured one then a brand new one simply because a tech. physically took it apart, inspected it, and fixed whatever needed to be fixed. Problem with a brand new TC is that your orginal was brand new. What to say is the brand new TC isn't broken? Then if you keep hearing the griding noise the dealer will eventually give up and at the end say it is not the TC. Try to get a re-manufactured one, I've had mine in since summer of 2011 and haven't had any issues.
Old 04-10-2012, 10:13 PM
Q23's Avatar
Q23 Q23 is offline
Vehicle: 2011 Ram Sport
Q23 is on a distinguished road
There is a STICKY on this whole issue... its at the top of the 2011 forum
Old 04-12-2012, 07:03 AM
mustang8918's Avatar
mustang8918 mustang8918 is offline
Trim Level: Big Horn Crew Cab
Color: Gray
mustang8918 is on a distinguished road
Always good to get some new info, re-manufactured it is then.
Old 04-12-2012, 10:20 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
is this a specific issue only related to the 2011 with the 5.7?
Old 04-13-2012, 08:23 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
No, the 4.7Ls are affected, too.
But as I've pointed out, this is only a noise issue, not a durability issue. The problem is rattle of the turbine hub spline when the torque converter clutch (TCC) is fully applied. Splines with too much clearance (backlash) can exhibit a "warble" noise (which I think has been best described as sounding like a Frisbee sliding across smooth concrete). The spline clearance will vary from converter to converter (due to manufacturing tolerances), so some are quiet and some make noise.
So if you get the noise and it annoys you, get the converter replaced. But if you have to really listen carefully to hear the noise, or aren't sure you even have it, then you don't have to replace the converter. It is not going to self-destruct prematurely!
Old 04-13-2012, 08:38 AM
Blackthunder's Avatar
Blackthunder Blackthunder is offline
Vehicle: 2011 Dodge Ram 2500 HD
Blackthunder is on a distinguished road
Transengineer-
I did have my TC replaced over a year ago. This eliminated the whining/grinding noise, but I still can hear the "frisbee" noise at times. That being said, with the splined part rattling around, would this eventually contaminate the TC by producing metal fragments/chips due to the sloppiness? Will this "frisbee" noise get worse? At this point it does not bother me enough to go through the hassle again with Chrysler and my dealership for a second replacement.
Thanks.
Old 04-13-2012, 09:08 AM
Vehicle: N/A
Rep:358
Originally Posted by Blackthunder View Post
Transengineer-
Thanks.
I would not expect any contamination issues. This spline does not get "ground down" in operation. If anything, there may be a slight increase in backlash (and thus, some increase in noise level) as the first few teeth that come into contact get peened down. But once the load is spread over more teeth, I would not expect any progression in spline wear (or further increase in noise).
We are not talking huge amounts of backlash here. We have found detectable noise with as little as .004 inch of backlash. That's why we went to a riveted design for 2012 MY - it eliminates the backlash altogether.
