Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Mopar Online Parts - Dodge Ram Accessories!
Mopar Online Parts - Dodge Ram Accessories! Suppliers of Genuine Dodge/Ram Parts and Accessories at wholesale prices. Shop with confidence as all repair parts orders are checked against the VIN provided to ensure 100% accuracy getting you the right part the first time. All items we sell are backed by a 1yr warranty. - Dodge Ram Accessories!
Old 04-10-2012, 02:13 PM
mmcglynn264's Avatar
mmcglynn264 mmcglynn264 is offline
Vehicle: 2011 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
mmcglynn264 is on a distinguished road
Default P/N for Uconnect, USB cable & Upper bin
I have a 2011 1500 SLT. It has the 130 RES with Sirius but no Uconnect. If things go as planned I will be getting a good price on the 430N RHB head unit. I have the upper glovebox with light. I need the correct part numbers for the uconnect module, the upper bin with the hoe for the USB port and the actual USB cable that goes from the Uconnect module and mounts on the back of the upper bin. If I've been reading correctly, certain modules require certain interface cable to operate properly.
All the part number listings I found for the cable seem to be for the Ipod specific connection or one called universal interface cable which requires drilling a hole in the bin. I want it to look just as if it was factory installed.
Any help on this would be greatly appreciated.
[B]RetraxPro tonneau cover; Mopar Power Tailgate Actuator; CoverKing NEOSUPREME RED w/BLACK SIDES; AMP Reasearch Powerstep; Mopar Molded Splash Guards; Husky WeatherBeater Floor Liners[/B]
Old 04-10-2012, 02:47 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
You will need the MOPAR kit # 82212159. This is the Uconnect kit that comes with the mic, harness and main module. You will also want to get the USB/Ipod cable, PN 82212160. This part will have a grommet on it where you can drill a 1" hole in the glovebox and fit the grommet into the hole.
If you want it to look fully factory, then replace the bin (I don't have this PN) and you will actually need PN 68068280AA for the USB/Ipod cable. It has a different mounting housing on it and also has a lighting ring around it. It is also a longer cable that can reach the center console.
Old 04-10-2012, 02:49 PM
Rep:73
Old 04-10-2012, 03:32 PM
Found this thread with pictures P/Ns: http://www.ramforumz.com/showthread....install&page=2 The only part number i cant find is for the USB. That thread about even includes the right color bin for my truck. However, jmr already had the uconnect and the usb cable. Is the part number you gave for the USB the same one shown in the picture on the above link? That's the one I need. BTW, I have the bench seat so there is no center console in my truck.
Old 04-11-2012, 07:15 PM
Rep:73
The cable that is pictured in his hand is the PN 68068280AA. It's the one you need for the factory look.
Old 04-11-2012, 09:04 PM
Thanks for all the info xsdbs. Once I get the radio, I'm ordering these parts. One last question. The usb port on the Uconnect module itself, is it a mini USB or micro?
Old 04-12-2012, 10:38 AM
Rep:73
You're welcome. It's a mini USB male.
Old 04-12-2012, 02:15 PM
Thanks, I'm probably going to make my own mount instead of using the factory cable. Cheapest price I found was around $46. That seems nuts for a usb cable. Lighted or not. I'll research a good panel mount USB cable & place it in that upper glove box.
Old 04-12-2012, 03:05 PM
Rep:73
Yeah, I saw it for around $55 and the 82212160 is about $35. (non lighted)
Old 04-13-2012, 07:45 PM
Thanks again for all your help. I have a question though. The USB in the glovebox that is connected to the uconnect module allows you to plug in an ipod and then control it from the HU correct? I'm trying to decide which lockpick to get and if the USB does allow ipod control than the CCH550 lock pick with the ipod connect cable would just be redundant. Also, where woulfd you suggest I purchase the Uconnect module in order to ensure i get one that is not outdated? or does that not matter?
