Dodge can't fix it your my last resort - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-10-2012, 06:51 PM
Emorris69 Emorris69 is offline
Vehicle: 2011 Ram 1500 SLT
Rep:40
Emorris69 is on a distinguished road
Default Dodge can't fix it your my last resort
Hello, Im a brand new member and Ive joined because I have a problem with my in dash usb port. My problem started after the deal put a whole new u-connect module in my truck. When I plug my black berry a Bold 9780 it gives me an error that the charging source is insufficient to charge my phone then there is a more info option and it is completely un helpful. So after I first noticed this I tried charging my iPad 2 to see if I would work but it tells my "not charging". So I took it back to my dealer and they tried an older black berry and it charged. So i don't have any clue what its problem is. I have owned the truck since day one and up until they replaced the modules it worked fine. I tried changing the cords out and not success. Both my phone and iPad 2 charge in the wall and my computer. I had it in today and they tell me that a call has been put into tech line and i need to wait on an answer. But I'm hoping some one here can help me.
Thanks
Emorris69
Old 04-10-2012, 07:04 PM
Rep:2968
Welcome to the RamforumZ
You may want to ask this question in another post
you should add the 3 letters that are on your radios face, lower right hand corner, when asking
I will see if i can find the correct post
Old 04-10-2012, 07:15 PM
Rep:40
Thanks for your speedy response. My radio code it RES.
Old 04-10-2012, 08:39 PM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
pick up a meter or see if you can borrow one and check the voltage.
Old 04-10-2012, 08:50 PM
Rep:40
With a usb this is impractical as to properly measure the out put voltage you need a device hooked up in series other wise no demand will be placed on the system and the load will be low. It doesn't matter what the voltage is any way you need current to charge a battery.
Old 04-10-2012, 10:05 PM
Ironsides Ironsides is offline
Vehicle: 2009 Dodge Ram 1500 CC 4X4
Trim Level: SLT Big Horn
Rep:44
Ironsides is on a distinguished road
Why was the uconnect module replaced?
Old 04-10-2012, 10:12 PM
Rep:40
When they tried to put the update on it they killed the original module some sort of programming error
Old 04-10-2012, 10:59 PM
Chunkem's Avatar
Chunkem Chunkem is offline
Trim Level: Longhorn Rambox
Rep:1648
Keep us updated and let us know how you make out......
Old 04-11-2012, 09:23 AM
Hex's Avatar
Hex Hex is offline
Rep:30
Hex is on a distinguished road
as far as one device being read and another not, that would make me think it was the software. But the software version should not affect which object is charging and which is not. A power source is a power source. Could possibly be a loose connection from the install and just happened to work when the dealer plugged his phone in, and not work when you plugged in yours.
Are you getting any other issues with the Uconnect? with the software or programming?
Old 04-11-2012, 09:42 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:400
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
i would go back to the dealer and make them change it again and tell them to reflash the sofwar in the computer
is was working before so its your right to make them re-change it,. also bring your phone and ipad2 to show them its not working,... if you have acces to a other phone thats also not charging like you wife phone or a friend bring that phone also ,..
if they dont whant tell them youll call chrysler head office and complain.
even if they sent a email to the techs.... do you think they will try to repair de deffective unit or thell change it once they get the answer back in a few months... so why wait
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover, powerstop brake kit.
