Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 04-11-2012, 03:53 PM
Emorris69 Emorris69 is offline
Vehicle: 2011 Ram 1500 SLT
Rep:40
Emorris69 is on a distinguished road
Here is a picture of the error I get
Old 04-11-2012, 03:54 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
what radio do you have? Must be the RES or the REQ. Is this correct.
The USB connector goes directly into the Uconnect module which is located to the far right side of the dash structure. If you drop the glovebox all the way down toward the floor. Look inside the dash to the far right, you will see a black module about 4"x6". It'll look like the the one below. (the PN may be slightly different but it looks just like this one)Can you take a picture of the module so I can see the PN & SW version? Also can you check the smaller connector and make sure that it is seated firmly. Thanks
Originally Posted by Emorris69 View Post
I believe I screwed up in the beginning, I have no radio usb. Only the one in my glove box and that was what I have always used to charge my phone. I had a similar thought about the amperage output from the glove box usb but never thought enough to check the specs. XSDBS I currently have a call into my dealer to get the info you asked for, I believe you are correct that they killed the original modules and screwed something up big time. The other thing is that some times it doesn't say its not charging it just doesn't. Im assuming this is what the dealer had happen when he used his phone.
Old 04-11-2012, 03:58 PM
Rep:40
Sorry yes I have the RES it was in my second post an other sight on my part. Im new lol. Yea ripping my dash apart no big deal, give me like 30 min. Ill be back.
Old 04-11-2012, 04:00 PM
Rep:40
Ok I took the laptop with me. So don't go any where i might need some help.
Old 04-11-2012, 04:03 PM
Rep:40
Well never mind that was easy, Here she is
Old 04-11-2012, 04:10 PM
Rep:73
Yeah, that's the same as I got plugging into the radio usb, but we're past that now.. Let's concentrate on the glovebox & module area now, ok.
Old 04-11-2012, 04:13 PM
Rep:73
I see that your truck is listed as a 2011. Do you know the build date? There may be a sticker on the drivers door, look for code MHD.
Old 04-11-2012, 04:15 PM
Rep:2804
there are 2 RES radios
one does Not have the phone on it & does not work with Uconnect
I believe that you have this one, i see it does not have the USB on the radio face
The other one does have the phone button on it & works with Uconnect
http://www.chrysler.com/en/owners/quality/res/
A bit more about your RES
http://www.oemautopartsco.com/amfmcd...-res-p-36.html
Old 04-11-2012, 04:18 PM
Rep:40
The build is 10-10. The MHD is 100510. My trim code is V9V3
Old 04-11-2012, 04:21 PM
Rep:40
All I know for sure is I have U connect and that works fine (now) I have one usb port in my upper glove box and up until they put a new module in it 30 days ago it charged my black berry fine for over a year
