Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 04-11-2012, 11:11 AM
stx4x4 stx4x4 is offline
Vehicle: 2013 Dodge Ram 1500
Color: True Blue Pearl
stx4x4 is on a distinguished road
Question Front End Control
I have a 2008 Ram 1500, my question is, When ever i am driving and im between 65mph and 75mph, when ever i hit a bump or drive down a crappy bumpy road, the front end feels like im going to loose control!!! feels loose, and very shacky, scared i might one day loose control and reck, does or did anyone have this same problem, the ruck is at dealership now, havnt herd form them, they had it since monday, kind if nervous they wont be able to find problem!!
Old 04-11-2012, 11:16 AM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:65
gusman will become famous soon enough
Every IFS vehicle Ive ever owned has done it. Seems to get worse if you level it. Just comes with the territory I guess. Try not to lean on your steering wheel or if you see a bump or expansion joint coming up, just lightly hold the wheel with your fingers, it always seemed to really get scary if I was resting my arm weight on the wheel to one side or the other.
Old 04-11-2012, 11:57 AM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
get your self a Steering Stabilizer
http://thurenfabrication.com/ramstab.html
This will help 100% also start looking into Energy Suspension Bushing kit and Replace all your Front end OEM rubber bushing for Polyurethane Bushings which helps keep unwanted wear and tension on the front.
Old 04-12-2012, 05:30 PM
Default front end
guys thanks for the advice, gusman, what is ifs vehichle, also i assume these trucks, as well as other trucks dont come with steering stabilzer???? is the steering stabilizer hard to put on your self?
Old 04-12-2012, 05:32 PM
Default front end
well just got a call from deelership, they couldnt find any problem, said they checked the bushings, the control arm, everything pretty much with the front end, thoguh they did say they coldnt go between 65-80 for to long seeing there area lto fo speed traps, so i guess ill just pic it up take both of your advice and go from there! thanks guys!
Old 04-13-2012, 07:09 AM
gusman's Avatar
Rep:65
IFS = Independent Front Suspension. And I'm not sure if you can put steering stabilizers on trucks with anything but a solid front axle. I could be wrong tho.
Old 04-13-2012, 12:12 PM
Rep:12
steering stabilizers are not hard to put on but will take some sweet and muscle. These parts help 4X4 and 2WD Rams. They work very well on street as for off roads. Look into Energy Suspension End links, Stabilizer bar bushings and more. Trust me you never have to go back and fix anything. It keeps the IFS strong.
