Old 04-11-2012, 01:39 PM
Supertex Supertex is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Supertex is on a distinguished road
Default Will 35inch Tires fir on my 2007 dodge ram
My truck has a leveling kit on it and it looks like i could throw them on it without any trouble but i just want to pick every bodys brain thats smarter and has more knowledge than me lol!! which is everybody lol!! Here is a pic of the truck i got to turn into something!
Old 04-11-2012, 04:06 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
You should be able to fit a 35" tall tire fine, especially with a level. The limiting factor is the width. I'm going to assume you have the stock 20" wheels? With those, the widest you can go is a 285 without it rubbing on the upper control arm unless you run spacers. If you have the factory 17" rims it might be a little different. I'm not sure how the backspacing on those compares to the 20" rims. Also, if you had an aftermarket rim with less backspacing than factory you could run a wider tire. Hope this helps.
Old 04-13-2012, 08:56 PM
06RAM's Avatar
06RAM 06RAM is offline
Vehicle: 2014 Dodge Ram 2500
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 350hp 660lb/ft (6-Speed Manual)
06RAM is on a distinguished road
I have the blistiens up front on my 06 set at 2" and 295/70/17 nitto trail grapplers on some moto metals. i think any bigger would rub.
Old 04-17-2012, 10:49 PM
VanillaHemi07's Avatar
VanillaHemi07 VanillaHemi07 is offline
Vehicle: 2007 RAM 1500
Color: Cool Vanilla
Rep:15
VanillaHemi07 is on a distinguished road
I have the same truck as OP, I ran a 295/60/20 on stock rims. Had to run 1/4" spacers to clear uca, but plenty of room, height wise. I have a 2" level kit on mine as well. The website says 295/60/20 is 34.5" tall, not true 35. Know a guy in town running 35/12.5/20 toyo mt no rubbing height wise, but not sure if it is an '07.
2007 RAM, 4x4, 2" HBS Level, Eagle Alloy 050 Rims, 34" Nittos, K&N Filter, Flowmaster Exhaust
Old 04-17-2012, 10:55 PM
hemi07's Avatar
hemi07 hemi07 is offline
Vehicle: 2010 ram
Color: blue
Rep:12
hemi07 is on a distinguished road
I have a 2" leveling kit and i have the stock 20s with a 285-65 i dont rub
