Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Towing
Towing 1st Gen Dodge Ram Towing Questions
Old 04-11-2012, 07:36 PM
qbancane qbancane is offline
Vehicle: 2011 dodge ram 1500
Trim Level: st
Color: silver
qbancane is on a distinguished road
Default towing travel trailer
i have a 2011 dodge ram 1500 st regular cab 3.7 v6 engine. i want to know how much can i tow? i want to but a travel trailer that weighs about 4000lbs,
thanks
Old 04-11-2012, 08:24 PM
Rep:2642
If you have the short bed Ram, you can tow more than with the long bed Ram, both with the 3.7 L engine
read the notes at the bottom of the charts
http://www.rambodybuilder.com/2011/d...ammlup1500.pdf
short bed = 3750 pounds
long bed = 3600 pounds
Another Dodge site reads differently, i did the BY VEHICLE part, you have to fill in the Year, the Vehicle, Bed Size, & Engine
2009 DODGE RAM_1500 1500 REG ST, REGULAR CAB, 2WD, SWB Bed, 4-Spd. Automatic VLP 42RLE Trans, 3.7L V6 Engine:
With 3.92 Axle Ratio Axle Ratio [i] You Can Tow 3850 lbs
http://www.dodge.com/towing/D/vehicle_to_weight.jsp
Old 05-10-2014, 07:26 PM
fantomII fantomII is offline
Vehicle: 2014 RAM 3500
Trim Level: Larmie, 4 X 4
Color: Red/silver trim
Rep:21
fantomII is on a distinguished road
Default Towing a 4000# trailer
I just purchased a pickup after towing my 5800 lb travel trailer with a Jeep GCherokee with the 5.7L Hemi. What ever your towing capacity is and yours is around 4000 lb., you can still tow a trailer on level ground but woe be when you hit even a slight grade. My Jeep was rated at 7200 lb towing capacity but I found (and can't remember where I found it) a web site that shows what the trailer weighs when you start going up a hill. For every degree of angle your trailer gains a lot. My 5600 lb trailer weighed about 8500 lbs on a hill with a 6% grade which went way beyond my max capacity. Again, the trailer can be towed with a small engine car so long as there are no hills and the tongue weight doesn't bring the front wheels off the ground. Its the hill and added heat that will kill the motor and transmission.
Old 05-11-2014, 10:18 AM
Hermes1 Hermes1 is offline
Vehicle: A truck
Rep:2554
Also keep in mind your tow rating is reduced by any passengers weight, drivers weight over 150 lbs., cargo and accessories. it is also good idea to allow a cushion rather than bumping up against the tow rating, especially if hills and mountains are involved.
