Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 04-11-2012, 11:33 PM
glogan glogan is offline
Vehicle: 1994 Dodge RAM 3500
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
glogan is on a distinguished road
Default What is the name of the part that attaches the Fuel Tank Filler Neck to my fuel tank?
I'm trying to figure out the name of the part which attaches the fuel tank filler neck to my fuel tank. (If it is a part.)
It appears to be an insert attached to the fuel tank, and not an integral part of the tank, but I'm not totally sure without totally removing the tank. It looks like it is a grommet with a lip. The filler neck attaches to it. But the parts diagrams I've seen do not show it separately from the fuel tank.
It got cracked when one of the fuel tank straps broke. Now when I attempt to fill the tank, the diesel leaks out at the place the Filler Neck attaches to the tank.
So is it a separate part from the fuel tank which I can purchase? And if so, what is it called?
I have a 1994 - RAM 3500 Cummins Dually.
TIA, Gary.
Old 04-11-2012, 11:42 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Nope you can't purchase it separately.
There's the tank with the collar, rubber hose, then the filler neck.
Old 04-12-2012, 09:50 AM
Thanks for the response. I guess I'll give a shot at sealing it, otherwise I'll need to replace the fuel tank.
Best Regards, Gary.
