Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 04-12-2012, 03:28 PM
whitey543 whitey543 is offline
Vehicle: 95 Ram 2500 Cummins 4x2
Color: silver/maroon
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
whitey543 is on a distinguished road
Default Fluctuating Oil Pressure Indication
I've been towing our 8,000 pound 5th wheel down to CA from BC, and normally my oil press is stuck at 275, but it has been drifting down to almost 0, then back up for a while, then back down. No other indication of trouble (engine keeps purring right along). Even tapping the brakes will make it jump back to normal for a few minutes. Oil quantity checked ok. Just had it changed.
I'll have my guy check it out when I get back if for no other reason than I want the gauge fixed, but any ideas? Am I doing damage?
Thanks.
Old 04-12-2012, 04:44 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Red face oil
Could be a gauge or sending unit problem but you may want to drop the pan and make sure you don't have some crap clogging the pickup.
Old 04-13-2012, 01:51 AM
Default Oil Pressure
Thanks, the weird part is that tapping the brake pedal at highway speed will affect it, even though the truck isn't changing speed at all (which might possibly dislodge crap in the pickup?).
If the oil pump really wasn't pumping, would I be able to run for 15 minutes at 60mph towing 8000 lbs?
Old 04-13-2012, 04:08 PM
Color: Grey
Rep:27
Red face Pressure
I think your pump is fine,and it is probably an electrical problem but if you want to make sure about the pickup it may be worth a look. When you tap the brakes, does the pressure immediately go up or gradually climbs? If it goes up right away I'd say that it's an electrical problem for sure. I don't think the pressure pickup sensor should be too expensive. Maybe try a new one.
