Old 04-12-2012, 03:19 PM
jssmith76's Avatar
jssmith76 jssmith76 is offline
Vehicle: 1997 Dodge Ram 1500
Color: Green / Black
Rep:26
jssmith76 is on a distinguished road
Send a message via MSN to jssmith76 Send a message via Yahoo to jssmith76
Default '97 1500 Front 4x4 Hubs...
Ok, gotta replace both of my front hub assemblies. Drivers side has a lot of play, passenger and some play. Found this out when I went in to get my brakes serviced. Anyways, that brake shop said they would charge me $600 per hub, plus $120 to install both of them. I said thank you, but no thank you. They did say that if I go elsewhere to buy the parts, they'll still install them for the $120 quoted, so I might go back and have them install for that price though. Dunno.
Anyways, looking online and saw a couple different hubs at AutoZone for about the same price. One was a Timkin, the other was a Duralast. Just wanted to pick your all's brains as to what would prolly be the best for the buck that's out there. I do some light offroading, mudding, etc... Tow a trailer occasionally. Other than that, just everyday driving in the warm Arizona deserts.
If you have any insight, opinions, or anything else, let it fly. I want some good stuff to chew on before a drop a few hundred bucks on the parts.
Thanks,
Josh
Thanks,
Josh
33" Goodyear Wrangler's on 16x8 ProComp Xtreme Alloy 1869's; Spectre CAI, Flowmaster Super 40 Cat-Back Dual Exhaust, Firestone RideRite Air Bags, Grille Guard, Step Bars
Old 04-12-2012, 06:15 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Josh, I did mine and replaced the u joint on the right side in under an hour in my driveway Saturday.
I'd prefer the Timken as I've used Timken bearings in the past and have had no problem with them.
As for the installation fee.
Loosen the outer nut (38mm I think)
Jack it up and take off the wheel
Remove the caliper (10 mm allen) and brace it up
slide the rotor off
remove the 3 14mm (9/16) 12 point bolts that hold it in and tap it out
Reverse.
By the way I also posted in this thread that'll lead to this thread http://www.ramforumz.com/showthread....183#post775183
WooHoo
Old 04-13-2012, 10:49 AM
jssmith76's Avatar
Rep:26
Sweet. Thanks for the replies. Good idea bout the u-joints. I did replace one of the hubs a few years ago (passenger side). Of course, I was expecting the bearings to come out by themselves, and actually succeeded at that. Shortly afterwards, I found out the hub assembly comes as one unit, not separately. So, I started to take the rest off. Long story short (too late prolly now), I had wait a few days for a buddy of mine to "break" a bolt for me. He's a good 350lb, former Marine. He had to put all his weight in to break that bolt loose. Hopefully, if I do this myself, I don't have the same things happen.
Thanks,
Josh
Thanks,
Josh
Old 08-25-2012, 07:32 PM
gman1951 gman1951 is offline
Vehicle: 1995 ram 1500
Trim Level: basic
Color: dark hunter green
gman1951 is on a distinguished road
Default secret tip
If ever you have rusted or siezed bolts or nuts to remove, get a can of Kano Kroil. It is the best penetrant (IMHO) made. It will penetrate 1 millionth of an inch crack. I just tore my 95 down for a plenum/throttle body repair/ mods and the wheel hubs,u-joints,tracking bar, and offset ball joints are on my list of to do's. Good luck with all your endeavors.
