Old 04-12-2012, 06:11 PM
cutlerkw cutlerkw is offline
Vehicle: 2011 Dodge Ram 1500
Color: Metallic Black
Rep:37
cutlerkw is on a distinguished road
Default Rough Country 2.5 level kit ball joint problem
Hi all, haven't been on in too long since I've been busy, but I my girlfriend got me a Rough Country leveling kit as a present recently. I decided to try and put it in one day after work, and everything was going great till I tried to loosen the upper ball joint, specifically the ball joint nut. It's stuck on there pretty good. The directions say to just remove it with a socket/wrench, however, when I turn it all it does is turn the whole ball joint shaft. Any good ways to get it off?
Old 04-12-2012, 06:18 PM
ironwill130 ironwill130 is offline
Vehicle: 2011 ram 1500 quad ca big horn
Trim Level: lts
Color: grey stone metalic
ironwill130 is on a distinguished road
yup put a pry bar inbetween the controll arm and u have to put a little pressure on the ball joint to prevent it from spinning with the nut
Old 04-12-2012, 06:54 PM
speedfRReak's Avatar
speedfRReak speedfRReak is offline
Color: White/Silver
speedfRReak is on a distinguished road
Also helps to burn the locktight out
11 Dodge Hemi Ram Laramie 4x4/06 Honda CBR1000RR/
86 Nissan 300ZX/65 Buick Skylark Convertible.
Old 04-12-2012, 06:57 PM
Rep:37
so basically I should put the pry bar in there and push so the upper control arm is pushing down onto the nut?
