Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 04-12-2012, 05:26 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
Default mds vs heavier oil
what is the reason mds will not operate with anything other than 5-20 wt. how does a 5-30 negate the mds? tks all
Old 04-12-2012, 07:38 PM
Q23's Avatar
Q23 Q23 is offline
Vehicle: 2011 Ram Sport
Q23 is on a distinguished road
where did you get this info from??? Yes 5-20 is recommended from factory but where does it say that it wont work with other viscosity? I dont see how it would be able to tell the diff between 5-20 and 5-30
Old 04-12-2012, 08:28 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
I thought the connection with 5W-20 and MDS operation was confirmed by Dodge, and I thought I first read about it in an Allpar article online...but I don't know exactly where that article is now.
Old 04-12-2012, 08:33 PM
Q23's Avatar
Q23 Q23 is offline
that would be some info that i would like to see. I would like to see the correlation between the two
Old 04-13-2012, 08:22 AM
Dak2 Dak2 is offline
Vehicle: 2011 RAM 1500 QUAD CAB 4X4
Dak2 is on a distinguished road
Here is the article
http://www.allpar.com/mopar/new-mopar-hemi.html
Down towards the bottom of the page.
Or TSB 09-015-04 and 09-013-04
Don
Old 04-13-2012, 10:06 AM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
Some time back had the dealer change the oil after about 1000 mls the oil change oil change light came on wonder what was going on checked the invoice and the mechanic had put 5w- 30 went back to the dealer changed no problem. I think but who knows that the MDS was working on the 5w-30??
Old 04-13-2012, 10:33 AM
TNC TNC is offline
Rep:12
Originally Posted by Dak2 View Post
Here is the article
Don
That's the article...thanks for finding that Dak. I noticed that they say it "may" cause a conflict with the MDS. Now, the interesting question is "how". The MDS works through the valvetrain lifters from everything I've seen and read...Allpar has one or more excellent articles on this. Hydraulic lifters obviously work on oil as the hydraulic medium. On the MDS models, there's another element functioning to disable the alleged unnecessary cylinders at the appropriate time. So the question would be, does going to a heavier oil possibly disable MDS or does it cause it to malfunction to a point where it comes in at a very inappropriate time? I would lean more toward speculating that MDS wouldn't kick in as frequently with heavier oil, perhaps because the oil is too thick to let the lifters disable those cylinders. But hey...I'm an old GM guy who knows very little about these Mopar engines and all their new fangled, space age technology...LOL!
Old 04-13-2012, 10:59 AM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
Uhhh... Uhhh .. why don't you want to use 5-20? are you unhappy with 5-20? My brother runs 5-20 in his 500hp shelby???
Old 04-13-2012, 11:07 AM
Trim Level: sport
Color: green
Rep:657
wvcoolvanilla, if your question is for me, i am asking because i was buying some 5-20 oil and was told that since warm weather was coming up i should use a heavier oil. went through the speal about mds and was told that a 5-30 would not affect mds at all. i bought 5-20 anyway.
Old 04-21-2012, 03:01 PM
mastertech10 mastertech10 is offline
Vehicle: 2013 RAM 1500
Rep:12
mastertech10 is on a distinguished road
reason being is that 5/30 gums up the oil galleries over a period of time.
i had one customer with a misfire caused by low pressure for the mds lifters, he was using 5/30. also if you go like 10,000kms between oil changes then you gum up aswell.
the oil passages on the hemi are sensitive to debris. even the screens on the vvt hemi are sensitive, wrong oil can effect the vvt operation aswell.
