Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 08-07-2008, 09:53 AM
gomango0042 gomango0042 is offline
Vehicle: 2004 ran
Trim Level: sport
Color: red
gomango0042 is on a distinguished road
Default throttle body light
the light is in the lower right side of dash look like lightning bolt. had it keep coming off on yesterday.when it comes on the truck gos to idle i press down on te peddle more it gos off and back to norm.seemed to happen most at about steedy 50 MPH alittle faster no prb.not kick the check eng light but will try to see if there is a code. has anyone else had this happen just wierd. will keep posted on it.
Old 08-09-2008, 02:47 PM
Vehicle: 2004 ran
Trim Level: sport
Color: red
turns out that it was a dirty conection at the throtle body if you ever have this happen just unplug it and use tuner cleaner or some other fast dry cleaner put on some white greese and hook back up.no prob for last several days.
Old 10-14-2008, 03:28 AM
Rouse5369 Rouse5369 is offline
Vehicle: 2003 Ram Quadcab 5.7l Hemi
Color: Blue
Rouse5369 is on a distinguished road
maybe this is it. ive had mine come on, and i first didnt know what to think it started hesitating and jerking i immediatly pulled over to see what was wrong. couldnt find anything and found out it was throttle position sensor. Mine resets if i pull over and just cut it off and sit a min or two and then start back up. The check engine light stays on but no more trouble with TPS. I have had this thing go for months without doing it and then itll happen. I d really like to hear from one of the mechs here, is there an adjustment they can make at dealership or do they just swap them out. and the cost. Or if this fix the gentleman posted before me legit. i dont doubt you at all sir, but i just found that by cutting my truck off and then back on it resets and i dont have sometimes for months.
Old 10-15-2008, 06:37 PM
Man from mars's Avatar
Man from mars Man from mars is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab S
Trim Level: SLT Sport
Color: Graphite Metallic
Rep:15
Man from mars is on a distinguished road
The throttle position sensors are replaced. They aren't very expensive and they are easy to replace. Sensors are sealed units and are not adjustable.
