Old 04-15-2012, 08:35 AM
jusrope1 jusrope1 is offline
Vehicle: 2012 Ram 1500/2006 Dodge 2500
Trim Level: SLT/Bighorn
Color: Black/Silver
Rep:27
jusrope1 is on a distinguished road
Default HELP, factory 20's won't fit truck that has factory 17's
couldn't find another post on this, today another member and I were trading wheels and tires, mine has factory 17's, his factory 20's hit the upper control arm, very weird, both 2012's, doest Doge do a different suspension depending on the size of wheels?
Old 04-15-2012, 10:04 AM
MoparDude's Avatar
MoparDude MoparDude is offline
Vehicle: 2012 1500 Hemi Crew
Color: Deep Cherry Red Crystal Pearlcoat
MoparDude is on a distinguished road
As a part of the deal on my truck, I had them swap out the 17's for a set of 20's on a Laramie... No problems here! Is your's a 4x4?
'12 RAM, '08 R/T Avenger, '66 500 ci. Belvedere
You save the environment, I'll save my dignity.
Old 04-15-2012, 10:22 AM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
I would think they work, unless maybe if one is 2wd and one is 4wd but even that I would think wouyld work, how wide of tires are you running?
Old 04-15-2012, 10:35 AM
Olddodgeowner's Avatar
Olddodgeowner Olddodgeowner is offline
Vehicle: 2012 Ram 1500 CC 4x4
Trim Level: SLT Bighorn
Color: True Blue Pearl
Olddodgeowner is on a distinguished road
I'm the other member he's trading with. Mine are 20x8 wheels, his are 17x7. Both with stock tires. Both are 2012 Crew Cab, 4x4. Almost identical trucks. The only difference is mine has Bilstein 5100's set to 2.8. I could understand if the 17' didn't fit mine for some reason, but they fit fine. Putting the 20's on his, they said the wheel itself hit the control arm, not the tire. Doesn't make any sense to me.
2012 Ram 1500 4x4 - Crew cab, Hemi
2000 Ram 2500 4x4- Cummins, QC, LB, 6 Spd
Old 04-15-2012, 01:52 PM
Color: Black/Silver
Rep:27
I was hoping someone would know, maybe I'll call Dodge tomorrow and ask them WTF
Old 04-15-2012, 02:45 PM
337ram 337ram is offline
Vehicle: 2009 1500 4x4
Color: grey
Rep:15
337ram is on a distinguished road
Is it the ACTUAL rim hitting or TIRE? I am betting tire
Old 04-15-2012, 02:52 PM
Color: grey
Rep:15
Another thought, my truck was bought new from dealer with aftermarket rims/tires, but on factory trucks there is clips on the hub around the lugs, are they present on both trucks?? Maybe that is how dodge/why dodge uses those clips, basically like a small spacer? Also how far was the 20s on your truck from mounting when they hit?? Also what tires are on the 20s??
Old 04-15-2012, 03:07 PM
Rep:2664
I had the clips on my Ram too
One of the guys at Discount Tire used to work at the assembly line
He said that when the vehicle is going down the line, the rims & tires go on at one station & when it gets to the next station in line, the lugs go on, those clips hold the rim on until the lug nuts go on. When the rims are changed for another type, they cut off the clips & toss them in the trash.
If the tires are not over 12 1/2" wide, they should not be touching, unless the offset on the rim is incorrect
Old 04-15-2012, 03:11 PM
Color: grey
Rep:15
Yeah I didnt know just heard about them, my truck never had them from the start, just scratching my head on how to stock rims wont swap, it could only be tires, and untill they answer what tires are on each wheel, I will still be scratching my head lol
Old 04-15-2012, 03:22 PM
Rep:2664
