Old 04-15-2012, 09:34 AM
djbeck88 djbeck88 is offline
Vehicle: 2012 1500
Trim Level: Lonestar
Color: Cherry Red
Rep:29
djbeck88 is on a distinguished road
Default Paying the price of the mud.
well Ive been playin a lot lately in the mud and its starting to take the toll on the truck last night I was out playing with my buddy in a f250 with 12" of lift and 37s. Well he tore through this hole that swallowed his truck past the headlights. He bet me I wouldn't go through it and I couldnt let the ford win against the dodge. I made it through it without a problem but now I think I got some electrical wet.
When I shut my truck off, its take roughly 3-5 seconds to turn off after I remove the key from the ignition. Also I keep getting p0462 code which deals with my fuel sending. but that comes and goes. And then somoething that comes and goes is that I looseeeeeeeee my oil pressure, fuel gauge and tempature and voltage gauges. Any one have any ideas? The biggest problem I dont like is that shutting off.
Old 04-15-2012, 12:52 PM
Vehicle: 2012 1500
Color: Cherry Red
Rep:29
Also, for the last few weeks, my key chime has been staying on when i pull the keys out of the ignition. sometimes it does it and sometimes it doesnt. But I just noticed as I was looking over things, My ignition isnt turning off my radio, the key chime still goes off, and now my gauges are doing full sweeps when I go to start it.
Old 04-15-2012, 01:28 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Ya got water in 'er. Dude, sounds like a beasty hole though.
You can ford up to 30" of water safely, so unless you TORE through it, I think you are probably mostly ok. Let her dry.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 04-15-2012, 01:32 PM
Vehicle: 2012 1500
Color: Cherry Red
Rep:29
Yeah I put a small hole in the radiator so i pulled ito ut and am getting it warrentied and had some water up in the air filter. fuse box was soaked, blew a relay. Ill take pictures when I go back out in a few hours and post them. It was pretty awesome.
Old 04-15-2012, 02:04 PM
tison1200's Avatar
tison1200 tison1200 is offline
Vehicle: 2012 Dodge Ram
Trim Level: express
tison1200 is on a distinguished road
I'd pull all conections that you can get at and dry them out real good and maybe put some of that electical grease on the plug before you plug them back in to keep them from corroding?
Old 04-15-2012, 10:41 PM
Vehicle: 2012 1500
Color: Cherry Red
Rep:29
Well I got my relay changed out and now I have 7 different CELs P0988, P0876 P0841 and then 4 different P0000. all except the P0000 deals with the Trans Fluid Press Sens/Switch e,a, or c Circ Range/Perf. Any Idea what that is???
Old 04-22-2012, 07:35 AM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
Sounds to me like you soaked the PCM. I'm not sure if they are supposed to be waterproof on these trucks but I'd pull it and drop it in a box of rice to dry it out..
Old 04-22-2012, 09:38 AM
Vehicle: 2012 1500
Color: Cherry Red
Rep:29
Well. I got it all fixed. I changed the fluid in the tranny and and tcase. put new filters in and now its works like new.
Old 04-26-2012, 07:00 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
sounds like you managed to suck a bunch of water into the trans/tcase vent(s)
glad shes feelin better!
2011 Big Horn 4x4 -SnowWhite-
Old 07-06-2012, 12:30 PM
KR15's Avatar
KR15 KR15 is offline
Vehicle: 2001 Dodge Ram 2500
Trim Level: SLT Laramie
KR15 is on a distinguished road
glad to hear your beast is back up to peak performance.
