Old 07-06-2012, 02:35 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Glad you got it all worked out bud. I definitely would go through all your connectors you think you submerged and cleanem up and letm dry. I second that vote on applying dielectric grease to the connections before connecting. Of course, make sure you remove battery cables prior to doing all this to help reset everything. Oh, and maybe take a look at all your vent tubes,(i.e., trans, rear diff, front diff if 4x4) and maybe consider lengthening them to getm positioned higher than top of wheel wells. I used to do this to my older trucks when I knew I was deep fording.
Old 07-07-2012, 09:35 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Glad it worked out for you....
Old 07-07-2012, 09:47 AM
EXPRESSIVE EXPRESSIVE is offline
Rep:49
EXPRESSIVE is on a distinguished road
[QUOTE=Gantman;835730. Oh, and maybe take a look at all your vent tubes,(i.e., trans, rear diff, front diff if 4x4) and maybe consider lengthening them to getm positioned higher than top of wheel wells. [/QUOTE]
In my old Jimmy I used to have, I ran the rearend vent up behind the tail light, the trans & transfer vents into the cab and the front diff up to the brake booster. Another neat little trick is to put a cheap clear plastic fuel filter on the ends (backwards facing), it keeps dirt out and since it on backwards you can see if it got any water in it.
Old 07-07-2012, 09:51 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
sweet cant complain about that
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
