Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 3.9L V6 Specifc Topics
Old 04-15-2012, 11:37 PM
rynmcdonald rynmcdonald is offline
Vehicle: 2001 Dodge RAM 1500 V6
Color: Green
rynmcdonald is on a distinguished road
Default 2001 ram 1500 3.9l
I have a friend who's RAM has got codes P1756 & 1757. I looked them up and noticed that it has something to do with governor pressure being more than zero at a stop. There's supposed to be a switch in the transmission that controls this pressure and that after replacing this if it doesn't fix it then it will need a new valve body (cerainly hope it don't). I hope some one here can help me out.
Old 04-17-2012, 02:42 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Aaaaaaand.......?
Old 04-24-2012, 11:48 PM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500
Rep:86
SnoopyIsMyHero will become famous soon enough
I have the same codes, it's an electronic piece attached to the throttle body. They run about $100 to replace.
2001 2500 5.9 4x4. Stock except for exhaust
Old 04-26-2012, 09:12 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
That electronic pice would probebly be map sensor. It is on the front of tb and messures vaccum pressure of eng and tells computer what shift points should be in relation to temp, throttle pos, and rpm at crank sensor
