Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
Old 04-16-2012, 01:21 PM
ugly97dodge ugly97dodge is offline
Vehicle: 2001 Dodge ram 2500
Trim Level: Base
ugly97dodge is on a distinguished road
Default Hi Y'all from KY. 2001 Ram Idle problems
Newbie here,
I have searched the posts and found some things that are interesting but wanted to explain my situation. My 2001 2500 4x4 5.9l witn 109k miles runs great except for now wanting to idle most of the time. I just bought the truck and it ran fine until I left the dome/cargo light on and ran the battery down COMPLETELY. After charging it back up it would not start. I cranked it quite a few times and finally hit the accelerator peddle once and it fired up but now won't idle. I cleaned the TB and removed the IAC motor and found a little carbon build up and cleaned it. Still won't idle without some accelerator peddle. Haven't checked the fuel pressure. It is not throwing any codes related to the TPS or IAC. The cat has been removed and duals added so it does throw O2 codes P0132 ND P0135. These were present when it would idle OK. I have looked for vacuum leaks and so far haven't found any. Now I am looking for any ideas you old time Dodge guys may have. Thanks in advance.
UGLY
Old 04-16-2012, 04:13 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Welcome to the forum,
This forum is full of great looking trucks; packed with great mod ideas and there are loads of knowledgeable and experienced people here.
You might try disconnecting the battery cable and leaving it off for about 30minutes and re-connect. When you recharge a completely dead battery, often the computer(s) start up at an improper voltage and have issues. This full reset may help. At least it doesn't cost anything and will rule out that possibility.
AND - We all like pix! Got any to share?
Enjoy the Z!
brad
Interested in one of my mods?
Old 04-16-2012, 08:27 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3944
Hello and welcome!
Good to have you with us, I hope you enjoy the board!
Old 04-16-2012, 10:43 PM
ShawnC13's Avatar
Cheap Canadian Labour
Rep:1739
Welcome joining here is a great decision for any RAM owner so much knowledge and information here!
Old 04-16-2012, 11:39 PM
Chunkem's Avatar
Chunkem Chunkem is offline
Trim Level: Longhorn Rambox
Rep:1637
Hello and welcome to the forum......We are glad to have you here......Do you have any pics of your truck......If there is anything that we can do to assist you please ask...
Enjoy the site....
Ed
Old 04-17-2012, 11:36 AM
Rep:4072
Hello and welcome to the forum, glad to have you join us! Sounds like a nice truck, any pics you can share? We'd love to see your ride in the gallery! I agree with Brad, good place to start is resetting the computer since it seems the problems started after the battery drained completely. Good luck and be sure to keep us posted! Lots of great people and info here so any help you need, just ask and I hope you enjoy the site!
Old 04-17-2012, 09:45 PM
Trim Level: Base
Thanks Brad but that didn't do it. I will be changing the IAC sometime this week. Hopefully that will do it.
Old 04-17-2012, 10:06 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Welcome to the Z! Nice to have you join us!!!
Big Red my old 2011 Sport
Old 04-19-2012, 09:44 PM
Trim Level: Base
Default KY newbie with idle problem FIXED
Replaced the IAC unit and all is well with the idle.
Old 04-19-2012, 10:47 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Thanks for posting the result...and
Welcome to the forum!
Glad to see that you wound up on the Z. There are different sections of the forum set up specific to the generations if you need help in the future. It's also a great place to just hang around. General Discussions and I've heard of an "off Topic" section.
Not to forget the vendors that can help with any modifications you might like to personalize your vehicle.
Take some time and brows the site, maybe even make a few friends!
Newbie how tos is always a good idea. It might help to familiarize yourself with how-to's on using the site and is a good reference tool for the future. One of the most underused aspects is reputation. It's used to say thanks to a member that may have helped, or pointed you in the right direction.
The little scales of justice in the upper-right hand corner of their reply has it. Just click on it and add to their reputation.
Also try to remember posting if you have an issue with your Ram and solve it. That also helps other members solve their issues.
Enjoy the site!
dies, idle
