Old 04-11-2012, 09:58 AM
Hemi4K's Avatar
Hemi4K Hemi4K is offline
Vehicle: 2008 Dodge Ram Hemi 4x4
Hemi4K is on a distinguished road
Default Front Shock Squeak
I had a set of ride adjustable Bilstein's installed last November by a small local shop and I've noticed the last couple weeks there is a squeak coming from the front end, mostly when I hit small bumps in the road. The weird thing is when I hit large bumps (speed bump or pulling into the driveway), there's nothing.
After some crawling around it looks like the piston is rubbing against the lower section of the top mount. I've isolated it by spraying some white lithium grease into the top mount from underneath and the squeaking will stop for 3-4 days. Also...when I feel around the top of the top mount (by the 3 mounting bolts and strut nut), it feels like the strut nut is offset in the top mount.
Did the shop forget to install some kind of bushing or washer?
I know a lot of guys have went to these shocks and I'm wondering if anyone else has had a problem like this.
Any help would be appreciated.
Old 04-11-2012, 10:16 AM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
would it be practical to have the shop check it out real quick ? i personally don't know..good luck
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter
Old 04-11-2012, 10:28 AM
Hemi4K's Avatar
It would but they moved and must've changed there name cause I can't find a number or address anywhere.
Old 04-13-2012, 03:50 PM
Hemi4K's Avatar
I found the shop that put my shocks on...place was locked up. Got a hold of the owner, explained my problem, and basically he told me he's not doing much auto work right now and it'll be a couple weeks before he's back to the shop (he said he was working for his dad...whatever). In other words..."not my problem anymore, sorry can't help". I guess that'll teach me to use the cheapest guy.
I took my pickup to another shop and had them look at it...they said there's definitely something screwed up. They thought there might be a bushing in the top mount missing. I'm taking it in Monday to get this fixed and move on. It'll end up costing me more in the long run, but lesson learned.
Old 04-24-2012, 12:25 PM
jkaluza's Avatar
jkaluza jkaluza is offline
Vehicle: 2007 Dodge Ram
Rep:13
jkaluza is on a distinguished road
The same thing is happening with my truck right now. I took it to a shop to get a leveling kit installed with new shocks and now it squeaks on small bumps but not so much on big bumps. I can also stand in the door frame and jump up and down and it sqeaks. I thought maybe the shock was bad or somthing but they dont seem to help fix it for anything. It also is crooked as the driver side front sits higher then the passenger side front. So the whole truck looks bad right now. Maybe somthing is not sitting right when they installed it.
2007 Dodge Ram
Old 04-24-2012, 01:10 PM
Hemi4K's Avatar
Get it looked at soon. That sqeak is probably coming from the shock piston rubbing on the bottom of the top shock mount. I ended up replacing both front shocks because the previous shop didn't tighten the piston nuts down all the way, which caused the bottom threads to be worn completely off.
Look at the thread titled "Expensive Lesson Learned". I've got some pics posted of what happens when you let it go too long.
Old 04-24-2012, 02:21 PM
jkaluza's Avatar
Rep:13
Thanks for letting me know what the problem most likely is. I am not going to drive it till i get it all fixed so that it does not end up costing me more in the long run. I am not happy at all with the company who did it so i think ill spend a little more and go else where.
Thanks again
2007 Dodge Ram
Old 04-24-2012, 07:52 PM
Hemi4K's Avatar
No problem.
Post back and let me know what you found out.
Old 04-25-2012, 08:41 AM
jkaluza's Avatar
Rep:13
I have an appt with Sam's Offroad out of Tulsa next week. Ill let you know what they have to say.
2007 Dodge Ram
Old 05-08-2012, 11:25 AM
testiclops's Avatar
testiclops testiclops is offline
Vehicle: 2010 Ram 1500
testiclops is on a distinguished road
bump. Any update on this? I'm having the same issue
"Please contact the Administrator if your date of birth has changed."
