Old 06-13-2012, 02:32 PM
Bocephus Bocephus is offline
Vehicle: 2012 Ram 1500 4X4 Crew
Rep:37
Bocephus is on a distinguished road
Does it require some modding as I notice even the chrome/silver part is swapped out as well
Just checked the sight....so many there. Which one is it?
That's a nice shifter. The shifter shaft simply slides over the stock shaft and tightens with a set screw. Mine was the same way. No modding required.
Old 07-11-2012, 06:24 PM
Rep:37
Finally got my rear shocks in from Bilstein.....5 months after i ordered them.
Bilsteins all around (front set at 2.8)
1" rear spacers
1" body lift
20x8.5 XD Spys (+18 offset) with hubcentric rings
285/65r20 BFG AT KO
No rubbing, no wobble, if anything it's a smoother ride.
Sets very close to level. About 1/2 inch higher in back just like i wanted.
Only thing left on my "to do" list now is a Line-X bedliner. I'll get that in a couple weeks.
Old 07-11-2012, 09:56 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
1" rear spacers
1" body lift
285/65r20 BFG AT KO
Question..... Are you bilsteins in the rear adjustable as well or you just got the heavy duty one and added the spacer?
Im considering doing the same thing just not sure on route....
sales@revelperformance.com
Old 07-11-2012, 10:11 PM
Vehicle: N/A
Rep:1045
That has a mean stance now. Looks sick man
Old 07-12-2012, 12:30 AM
Revel Performance
Rep:1804
Sorry...forgot to provide feedback
You have truly done a great job so far with all your mods
Old 07-12-2012, 01:00 AM
Rep:37
The rear ones are not adjustable, but they allow for an extra inch of travel allowing you to put a 1" spacer without changing the ride.
Every truck is different, but after looking and reading a lot, I decided to put the 1" in the back and it turned out great. I've seen others with nothing in the back and they look good too. Just depends on the truck. Good luck!
Old 07-12-2012, 01:18 AM
Revel Performance
Rep:1804
Thanks.
I think I'll either do without the rear or just get the rear adjustable one as well.
Do the 1" in the rear and 2.8" in the front.
This should almost level it but till give me the slight rake I want
Old 07-12-2012, 05:56 PM
Rep:37
Thanks.
Correct me if i'm wrong, but bilstein doesn't make an adjustable rear shock.
It says 0-1" beside the rear bilsteins (part # 24-187374) but that just means they have a longer travel and you can put a spacer if you want. There's no way to adjust them. A lot of people get confused on that.
Does somebody else make an adjustable rear shock?
Old 07-12-2012, 06:16 PM
Revel Performance
Rep:1804
I am one of those confused people. Lol
I got corrected from a bilstein distributor here in Canada.
What spacer did upon use?
Old 07-12-2012, 08:41 PM
Rep:37
I ordered mine from topguncustomz.
