Old 07-18-2012, 03:54 PM
Bocephus Bocephus is offline
Vehicle: 2012 Ram 1500 4X4 Crew
Rep:37
Bocephus is on a distinguished road
But now look at your truck....its BEAUTIFUL
Thanks man! Im really happy with it!
You ordered wheels yet?
Old 07-18-2012, 04:02 PM
Not yet....
Debating on tires now.
I have chosen my rim though (below)
Cant decide on tire:
295-60-20 Nitto Terra's
OR
33x12.5 Toyo MT
Possibly
35x12.5 Toyo MT (it does fit will minor, minor trim - WhiteKnight did it with Bilstein set to 2.8)
Thoughts on tire choice?
Moto Metal (20x9, 0 offset)
Just because your truck is red.... (I know, its a Tundra, but it looks damn good on it)
Old 07-18-2012, 06:23 PM
Ordered the Top Gun Customz 1" Coil Spacer....cause I want my truck to have a nice lift like yours
Where did you source out your 1" body lift? Why only 1"
Old 07-18-2012, 07:25 PM
Wheels officially purchased now:
(4)Moto Metal MO962 20x9" Gloss Black 0mm 5x5.5 (2012 Ram 1500),
(4)295-60-20 Nitto Terra Grappler AT outline out, mounted and balanced,
(4) DODGE TPMS,
(4) HUB RINGS,
(20)14x1.5mm BLACK Lugs,
all to Canada. Thanks!
Cant wait to receive it
Old 07-18-2012, 07:39 PM
Rep:37
(4) DODGE TPMS,
(4) HUB RINGS,
Awesome! That'll look great man can't wait to see em on.
I ordered the body lift from TruckProUSA.
Honestly I'm not a huge fan of body lifts. I don't think that's the way to "lift" a truck. However, I got bored waiting on my shocks and had to do something.
The 1" body lift was only like $100 and was super easy to install. Since it's not that much of a lift, you don't have to extend your steering linkage, gas tank lines, or a number of other components commonly associated with body lifts.
So, I figured for $100 and a few hours of labor, it was worth it.
Combined with the bilsteins, it's close to a 4in lift without all the $$$.
Old 07-18-2012, 10:42 PM
I always wondered how simple it was to install a body lift...
If you are saying a 1" is pretty easy and doesn't require lots of modding.....can I grab one more idea from you
Your stance is what I want on mine :smile up:
Hope it looks good on mine as it does on yours
Old 07-19-2012, 01:52 PM
Rep:37
It's not hard at all. I installed mine one evening after work.
My advice to you is use an impact. It'll make everything easier and faster.
Don't be an idiot like me and use ratchets and wrenches.
Old 07-19-2012, 04:02 PM
Check!
I got a cordless impact and wired one.
I will check the link you sent above for this lift....
so 1" will require minimal modding? Anything higher will?
Old 07-19-2012, 09:22 PM
Rep:37
For the most part this is true. You'll still have to do a lil grinding, drill new holes, etc. but you won't have to do a lot of things that a taller body lift would require. I've seen instructions for taller body lifts be twice as long.
Old 07-19-2012, 10:09 PM
Was this the one you got?
1" Body Lift
