Old 04-18-2012, 03:22 AM
Sport10's Avatar
Sport10 Sport10 is offline
Vehicle: 2010 Dodge Ram Sport, Quad
Color: maroon
Rep:21
Sport10 is on a distinguished road
Default BFG KO 275/65/20, What is Proper Tire Pressure?
Just like the title says...
I am very interested in peoples opinions/facts on what the best tire pressue is in these?
Best for MPG's?
I know there is endless threads on this subject but when doing a google search I couldn't seem to find a good answer on my tire.
I have the BFG 275/65/20 and i'm pretty sure it's an LT tire. I currently am running 36 psi (1 psi over door jam rating), and find my mpg's lacking. On the other hand comfort is very nice. I have a cold air intake, 18 mufflex, and cortex programmer w/93 tune, I average about 12.5 to 13 mostly city mpg. I don't drive like a maniac nor a grandpa, somewhere in the middle.
Also would increasing the tire pressure help with 0-60 and quarter times or make it more sluggish??
Looking for someone who has a vast knowledge of this subject...Please chime in, TX
Eric B.
2010 RAM SPORT 1500 QC, HEMI-
NOT AS MANY MODS AS SOME, BUT GOTTA FEW---
Old 04-18-2012, 03:31 AM
hemi07's Avatar
hemi07 hemi07 is offline
Vehicle: 2010 ram
Color: blue
Rep:12
hemi07 is on a distinguished road
I had mine at 36psi i just put it to 40 so far so good. Mine r 285-65-20 i got the same tire
Old 04-18-2012, 03:48 AM
Rep:2625
as a reference, you need to know that PSI is Pounds Per Square Inch
it does not matter if it a wheel barrow tire or a semi truck tire
35 PSI is the same in both
a semi truck is usually 65 or more PSI, because of weight & heat
race cars start with low PSI & pressure builds up after a couple laps at 100+ MPH
desert racers purposely run low PSI for traction
I know that i didn't answer your question, but it gives you a reference point
Old 04-18-2012, 04:15 AM
Sport10's Avatar
Color: maroon
Rep:21
Thanks for the refrence.
Would it be safe to say you are suggesting a higher psi for my truck then the suggested 35 on the door jam ?
I ask this cause of what you said about the semi truck, and lets face it while are trucks aren't semi"s there not prius's either.
More insight would be appreciated, thanks again
Eric B.
Old 04-18-2012, 04:19 AM
Sport10's Avatar
Color: maroon
Rep:21
This is actually what I was going to try next.
Would you say it is alot harsher now? Any improvement on mpg's?
Does your truck seem to have better pick up due to the increase in pressure?
Tx....
Eric B.
Old 04-18-2012, 07:53 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I don't know that there is a hell of a lot you'll be able to do to increase your MPG. I'm running stock tires, at about the same pressure that you have, and I'm getting about the same mileage as you are. I don't think changing the air pressure will make much of a difference, if any (just my opinion and I don't have any scientific data to back it up).
I've just accepted that the HEMI in a large truck that weighs a lil over 3 tons isn't gonna get great mileage. I am usually quite please if I'm close to 13 MPG, I do mostly in town driving with a few short trips on the highway (though I doubt they're enough to matter)
Enjoy your gas guzzling, almost 400 HP beast and accept that we'll never get the mileage of other smaller, less fun to drive vehicles
Exco
Bill
Old 04-18-2012, 05:54 PM
Sport10's Avatar
Color: maroon
Rep:21
I called BFGoodrich today and asked them what they recommend, and they said 50 in all 4 corners. Thay said the door jam number is for stock tires only, not for a bigger 10 ply tire, which makes sense to me.
This is what I did and took a short ride and I have no complaints, so will see how I like them in the long run.
I will post back at a future date to let you know abot mpg's and comfort..
Thank you to the people who replied.
Eric B....
Old 04-19-2012, 11:31 PM
clatla's Avatar
clatla clatla is offline
Color: Snow White
Rep:31
clatla is on a distinguished road
50 PSI thats alot for a 1/2 ton. I have the stock badyears and have run them at 40 since I got the truck. You will defianley notice a harsher ride with 10 ply and 50 psi. I would guess that you will wear out the centers long before the outer edges.
Old 04-19-2012, 11:42 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Higher the ply RATING, higher the pressure. That is on purpose, as psi factors into load rating. I capitalized rating because that is only what it is, there are not 10 ply's in the tire. The tire doesn't care what truck it's on, it takes what it takes for psi
"I don't care to hear what your ideas are, mine are better"
Old 04-20-2012, 01:08 AM
RedRamHemi's Avatar
RedRamHemi RedRamHemi is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT 4X4
RedRamHemi is on a distinguished road
I ran mine (BFG T/A KO's 285/60/20's) at 50 psi for a long time. Got 17 to 20 mpg avg. which I think is really good for this truck. The wear was even across the tread. No extra wear in the center. I dropped the psi to 40 recently because I could feel the truck seem to loose road contact over small road bumps, etc. . The road contact issue went away after lowering to 40 and the mileage is still the same and ride quality seems to be improved as in softer ride. Doesn't look like it would make that much difference, but it did, or, could just be me. I plan to try 45 psi and see what that does. BTW, my tires are rated to 65 psi max. pressure for towing and hauling. It has always been my experience that max. psi will get maximum tire life (and less rolling resistance which would equate to more mpg) at the sake of ride comfort. Hope this helps you.
Spectre Stainless CAI, Superchips Flashpaq,
FlowMaster Series 40 CatBack, Hurst Equipped, Tinted.
