Old 04-18-2012, 11:14 PM
Kcbigbadram's Avatar
Vehicle: 2014 1500
Trim Level: limited
Rep:503
Default Will these fit??
I'm looking at possibly leveling my ram with bilsteins, then I want some new rims and tires.
Question is I'm looking at some helo 835 with +18 offset then I want to put toyo open country AT on them. The size would be 325/65 18, which is a 35x13 18.
So will these work or will I be rubbing?
Thanks guys
Old 04-20-2012, 03:23 PM
Vehicle: 2014 1500
Trim Level: limited
Rep:503
Is anybody running 35 x 13 with just a level kit? Did you need spacers?
Old 04-20-2012, 04:17 PM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
I think to get a tire much wider than stock you are going to have to go with a lesser offset than +18, if I am not mistaken stock offset is around +18. I am not sure what offset exactly you will need but I doubt +18 will work. If there is an actual 35x13" wide wheel it may be too wide with just a 2" level
Old 04-20-2012, 06:09 PM
Vehicle: 2014 1500
Trim Level: limited
Rep:503
i was afraid the +18 would be a problem without a spacer, and i would rather stay away from them. the wheel itself is 18x9, but the tires im wanting to run are 35/13/18
