Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 04-19-2012, 08:09 AM
CIRCUIT BREAKER CIRCUIT BREAKER is offline
Vehicle: 2001 Dodge Ram
Rep:13
CIRCUIT BREAKER is on a distinguished road
Unhappy New Member needs help with 3.9 problem. Please help
I have a 2001 Dodge Ram 3.9, with 101,000 miles on it. Bought it new. This is the problem, Starts fine runs good for a few min. or 20 or more miles. Then it shuts off at idle just like you turned the key off. Will fire right back up just by turning the key, not off then on just start. If you are going with any speed it stops and restarts it's self ( chuges quickley) the check engine light will flash a split sec. before it dies at idle or chugs while moving at speed. No certain amount of time running before it starts screwing up. Will do it cold or normal temp. No codes
This is what I have done, but still have same problem:
Plugs,Plug wires,Dist.cap,Rotor.
Dist. pickup
Crank sensor
TPS, checked many times for bad connections or bad wires,found none
Checked fuel pressure,good
Coil?
Computer,any way to check? $350.00 at the zone
I,m lost.
Thanks for your help
Old 04-19-2012, 08:45 AM
MERF-09's Avatar
MERF-09 MERF-09 is offline
Rep:19
MERF-09 is on a distinguished road
I would test the coil for proper resistance also check your fuel sync signal on the distributor. can't remember what the resistance should be but you can google it & I'll look the info tonight in my book.
One Owner 2001 3500 Cummins 320,000 miles & still growing & 2001 1500 5.2 92,000 & still growing
Old 04-19-2012, 10:10 AM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500, 2001 Ram 1500
Color: 2500 White, 1500 Black
Rep:97
SnoopyIsMyHero will become famous soon enough
Does it have an AIC valve? I know the V8s do, those are cheap and do fail. It's what keeps the truck running properly at idle. My son's jeep would run great as long as you were on the gas, off it would die. Replaced that and problem fixed.
2001 2500 5.9 4x4. Stock except for exhaust, step rails but I don't care, I love my beast
2001 1500 5.2 4x4. Stock except for exhaust, my new project.
