Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 04-19-2012, 10:08 PM
Looey's Avatar
Looey Looey is offline
Vehicle: 1996 Dodge Ram 3500
Trim Level: SLT Laramie
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Looey is on a distinguished road
Default 1996 12valve leaks engine oil
So I bought a 96 ram last summer. It has 544000kms on it, runs great and it delivers great fuel mileage.
The problem is it leaks engine oil and I can't seem to find exactly where it starts, but it ends up in a puddle in my driveway, and after a good highway drive the tailgate usually has oil freckles on it which I thought might be from the road draft tube.
I've washed the engine down and looked for leaks, checked fasteners and the oil level is usually at the full line on the dipstick, Johnny.
Is there any specific part of the engine (timing cover, oil pan etc) that periodically requires new gaskets or should just I live with it and park it on the front lawn?
Thanks for reading.
Old 04-20-2012, 07:38 AM
MERF-09's Avatar
MERF-09 MERF-09 is offline
Vehicle: 2001 Dodge Ram
Rep:19
MERF-09 is on a distinguished road
I would look at the Vacuum pump I have had to replace that sea.l The oil was running down the drivers side front if you look up from the bottom of the truck you will see oil all over the shaft between the vacuum pump & power steering pump you can get the seal kit from Genos Garage.
One Owner 2001 3500 Cummins 320,000 miles & still growing & 2001 1500 5.2 92,000 & still growing
Old 04-20-2012, 06:19 PM
Looey's Avatar
Thanks Merf. I will start there.
