E-cutout location - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > Exhaust
Old 04-20-2012, 07:03 AM
crackerzach86 crackerzach86 is offline
Trim Level: SLT Big Horn
crackerzach86 is on a distinguished road
Default E-cutout location
I just ordered two electric cutouts from qtp, my question is does it matter where I install them as long as its after the cats and before the muffler? I've seen most guys put them right before the muffler, would it make any difference if I put them closer to the headers?
Old 04-20-2012, 09:52 AM
Rep:3347
If you ordered 2, then get them installed between the cats and the y-pipe. IF you have a true dual, then mount them anywhere between the cats and muffler, but as close to the cats as you can.
Old 04-20-2012, 01:55 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
If you have the real estate then right before the cats
Old 04-20-2012, 03:42 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
Not going to happen on a 4G without re-locating the cats
There's not much room between the cat and the cross pipe (drivers side) or the passenger side cat and Y pipe either.
You'd be better off with a single 3" cut-out right after the Y, before the muffler
or you could totally eliminate the Y , run true duals to dual cut-outs (install dual mufflers or a DI/DO muffler).
Old 04-21-2012, 12:39 AM
I am running a dual in dual out magnaflow 14" muffler and will probably have the cutouts installed right behind the crossmember for the diff. I've heard that putting them right behind the cats makes the noise in the cab unbearable.
Old 04-22-2012, 02:50 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
cutouts are for loud...try your best to install before cats (relocate cats)... after the cats may still sound a little muffled because of the cats...I deleted mine so any place before muffler would work...
Old 04-22-2012, 04:46 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
I have my QTP right on the Mag y-pipe about 6-8in before the muffler, plenty loud.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 04-23-2012, 09:06 AM
Wouldn't I get cel's if I installed before the cats? I don't want to have to deal with that.
Old 04-24-2012, 10:52 AM
chefred112's Avatar
Rep:656
it could...i run plug foulers to 'fool' the sensors and not get any mils
Old 04-24-2012, 10:54 AM
chefred112's Avatar
Rep:656
if runnin di/do muffler, go ahead and put it right after the bends (where the Y pipe would have been)....
and if you want the full effect, you'll want to delete the cats..eventually..
