Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 04-20-2012, 01:49 PM
jeffsw6 jeffsw6 is offline
Vehicle: 1997 Dodge Ram 2500 V10 2WD
Color: red
jeffsw6 is on a distinguished road
Default stock hitch receiver rating? 97 2500 V10 2WD
Could anyone help me find the rating of the stock 2" trailer hitch receiver on my "new" work truck? It is a 1997 Ram 2500 V10 2WD regular cab. I understand that the tow rating of the truck is quite impressive but the previous owner of the truck obviously did not use it for towing anything big, because it has never had a brake controller on it. The sticker on the factory receiver is long gone so I would like to know if I should upgrade it.
My trailer is a 8.5x20 10K enclosed model and actual weight when loaded is around 7500# to 9000#.
Also is using the overdrive when towing not recommended on the 47RE? I have not even owned the truck for a day, so I haven't had a chance to look over everything in detail, but if it does not have an auxiliary transmission oil cooler, I will add one. I am assuming the transmission oil is at least routed through the main radiator.
Thanks!
Old 04-22-2012, 12:54 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Is it a factory installed Class III?
I believe this is the correct info.
GTW 5,000 lbs
TW 500 lbs
WDGTW 10,000 lbs
WDTW 1,000 lbs
