tonneaucovered.com
Old 04-20-2012, 09:28 PM
Hemiblack's Avatar
Hemiblack Hemiblack is offline
Vehicle: 2012 Ram Express Crew Cab 4x4
Hemiblack is on a distinguished road
Default Check engine light is on and no Eco?
Hey guys...got a question for ya. On a road trip, and my check engine light came on and I started getting really bad gas mileage. I just figured it was bad gas and didn't think much of it but now I notice that my eco light isn't coming on either. If it was a bad tank of gas it should be gone now because that was three tanks ago. And my check engine light is still on. I'm getting between 15 and 16 mpg and I have gotten between 19 and 20 every other time on the highway. The truck runs fine and all the gauges are normal except for check engine and eco. Any ideas? Thanks.
Old 04-20-2012, 09:32 PM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
I just went through the same thing....
http://www.ramforumz.com/showthread.php?t=109827
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 04-20-2012, 09:44 PM
Hemiblack's Avatar
I just read your other post. Sounds like what I got going on. Any idea if this can be a DIY thing or do I need to find a dealer? I'm kinda in the middle of nowhere and I would hate to get stranded. Hopefully the truck will keep running. lol
Old 04-21-2012, 08:33 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
check engine light can mean many things. The easiest thing to do is take it to autozone or something similar and have them check the codes for you. They will do it for free. That will give you an idea of what it is. If you want to clear the code yourself without checking to see what it is you can disconnect the battery and that will reset the computer. As far as the eco light, it will not come on with the check engine light, but mds still works. coast at 35 and then barely press the throttle and you'll see for yourself. Good luck!
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 04-21-2012, 09:38 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
Later GM vehicles have the same issue with a nonfunctioning remote start when an active code is stored. I guess it's some kind of punishment to encourage the driver to go to the dealer...LOL! I think just about everyone who has any personal mechanical interest in their vehicle and a desire to really know what's going on with their vehicle's operation should probably purchase something like a Scanguage II or other code reader. You'll always know what code is thrown, and you can remove it if it's just a temporary. Plus the Scanguage II allows you to read real time engine functions on a very finite scale in the digital readout. For about $130 it's a good investment IMO.
Old 04-21-2012, 09:43 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Sometimes resetting everything will put the computer back into running mode, you might have had bad gas at some point the error will stay there generated by the computer till the fault is fixed., once the fault found and fixed they will reset the computer (dealer). But if the fault had been bad gas, the computer may still be in protection mode, only a reset will fix that (either by removing the power or reset by the Dealer). If you want, try and remove the negative pole on your battery for about 5 min, this will reset your computer, and your radio stations etc. and it should put the computer back in Normal mode, run your truck and see what happens, if the engine light returns, then you had a fault that really needs to be looked at, if it does not, you might see your mileage return to what it was. Since your not anywhere near a dealer that can tell you what the error code is I would do that first, but its up to you.
Old 04-24-2012, 12:42 PM
Butter's Avatar
Trim Level: XLT
Rep:398
From what I was told about mine something wasn't securely plugged, they checked the pins on the plug, plugged it securely, reset the fault and I haven't had any problems since. I'm lucky to have a good dealer 10 miles from me so as long as it's under warranty it's easy for me to let them handle it.
Old 02-09-2013, 11:50 PM
mtwoods mtwoods is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Outdoorsman Edition
mtwoods is on a distinguished road
Today I had this same problem - Check engine light and no eco. Dealership cant see me till Tuesday so I unplugged the negative from the battery to reset everything and when I started the truck after reconnecting the check engine light flashed a couple of times and turned off. Is it safe to call it a day or should I still waste half my Tuesday morning while the dealership spends 4 hours to do 5 minutes of work so they can screw the warranty company?
Old 02-10-2013, 12:00 AM
balloo balloo is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT Club cab
Rep:12
balloo is on a distinguished road
You may want to check to be sure the gas cap is on tight.
Old 02-10-2013, 12:43 AM
Gas cap was the first thing I checked.
