Old 03-08-2013, 10:47 PM
robpayneusaf's Avatar
robpayneusaf robpayneusaf is offline
Vehicle: 2010 Dodge Ram 1500 TRX4
Trim Level: TRX4
Rep:195
robpayneusaf has a spectacular aura aboutrobpayneusaf has a spectacular aura about
Yeah, I probably won't end up getting rid of my mineral grey. Just a thought. Apparently the plastidip is pretty forgiving. I might do it, then if I don't like it just peel it right off. I've done my emblems and some of my grille so far. The stuff's pretty cool.
Old 03-12-2013, 12:00 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Had to wash the truck to get em on LOL
Wow Matt! That looks like a lot of work. I hope you paced yourself over 2 days. As a Black Ram owner, I know how much effort it takes to clean the whole thing.
IDK about these swamp rats and the beer they drink.
brad
Interested in one of my mods?
Old 05-28-2013, 06:43 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
Added a 102" whip to the truck this weekend. Got too drunk to install cb, but at least I got this done
Decided to with the ball mount and spring, just because it looks good. Cost a shit load more though
MATT
Old 05-28-2013, 08:01 PM
Rep:1804
Damn man.
You can almost chat with me here in Toronto with that whip.
Old 05-28-2013, 09:23 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Wow, your gonna have to watch out for power lines with that thing, nice install.
Old 05-28-2013, 09:31 PM
AbnMP13 AbnMP13 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Longhorn Laramie
AbnMP13 is on a distinguished road
Where you gonna mount the CB?
SFC, US Army
Retired
Old 05-28-2013, 10:13 PM
Rep:420
Damn man.
On a good day where skip conditions are good I would be able to. But I'd have a better chance using my Stryker with the 1000 watt amp. My General Lee is going in the dodge, and it only does 150-175 watts
Yea it sits right at 13' 4" high. Power lines are generally higher than 15'. I was gonna mount the whip on the top of the headache rack but that would put me at 15'3" high I think. And that's cutting it too close LOL. My antenna on the big truck sits at 14'2" high and gets a lot of interference when going under lines
I'm gonna screw the mount into the dash, right above the little cubbyhole that holds two cans of dip above the radio. If it didn't have the amp on the back of the radio I would be able to scoot it back a bit. But the amp adds like 5" to the back so it cuts down on mounting locations. And besides its the only logical place to put it in my mind. Haven't quite figured out where I'm gonna run the wires but ill probably cut a hole in the dash and run them thru there. Just depends on how shitty it'll look when done
MATT
Old 06-01-2013, 02:18 PM
Rep:420
Got the radio mounted up. Now I just have to figure out where I'm gonna come in with the coax. Might just drill a hole in the floorboard and put a bunch of putty around it to keep water out.
I went with the standard cb mount. Drilled two 5/16" holes in dash and put the flat bar under the dash so the radio would pull on it instead of just two bolts. In the process I screwed up my Mic when taking it out the big truck, but it wad enough to check my SWRs. With amp off it doesn't even move the needle. With the amp on I have a 1.1:0 SWR. Which is good enough for me to leave the shit alone
Next time I come home ill finish everything up. I have to make time for beer drinking
I also used some sticky wire holder things to try and keep the wires nice and tidy. But I'm not too convinced that I like the way they look. Might have to change that up too
MATT
Old 06-01-2013, 02:35 PM
Vehicle: N/A
Rep:1045
badass man. that would look good at nighttime all lit up
Old 06-01-2013, 02:56 PM
Rep:420
Thanks bud. Yea its gonna look epic at night. With the green nitro knobs and 12 blue leds under the radio. Shits gonna be sweet
MATT
