Old 04-22-2012, 03:47 PM
kevinb kevinb is offline
Vehicle: 2009 Dadge Ram Quad Cab 4X4
kevinb is on a distinguished road
Default Problem with LED's in turn driver side turn signal indicator
Hello, this is my first post on the forum. I just got a 2009 SLT quad cab 4X4 and love the truck! I have a minor problem I could use some help with. The "approach" LED's in the driver side mirror turn signal indicator are not working. The ones on the passenger side work fine, but the ones on the driver side do not. The actual turn signal indicator on this mirror works fine. I searched the owners manual and cannot find the dis-assembly instructions to remove the lens to see what is going on in there. Any info would be appreciated. TIA!
Old 04-22-2012, 05:50 PM
brokenwrench66's Avatar
brokenwrench66 brokenwrench66 is offline
Vehicle: 2009 1500 SLT 4X4
Color: Stone White
Rep:81
brokenwrench66 will become famous soon enough
Welcome the the Forumz! Be sure and introduce yourself at the Newbie Checkin!
As for your question, try this:
"Lenses come off pretty nicely. Just use a soft bondo squeegee to get under the black trim around the edge of the mirror, pull the trim aft a bit which will allow the forward side of the lense to drop down with a slight pull, then pull the aft side of it down and slide the lense aft to disengage the lock tab up inside, remove the connector and voila!"
Dual Exhaust, K&N drop in, TFP chrome mirror covers, TFP stainless steel door handle covers, molded splash guards, Leer cap
Old 04-23-2012, 02:35 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Welcome to the forum!!!
The housing that has those LEDs in it is a sealed unit and is best to be completely replaced than try to replace one of the individual LEDs should those be found to have burnt out... trust me. Im LED crazy and while my drive side has blue puddle lights and white blinkers, my passanger side is stock and prolly staying that way
2011 Big Horn 4x4 -SnowWhite-
Old 04-24-2012, 11:41 PM
OK...I got the assembly off, and it has suffered water intrusion. Lots of green corrosion. Anyone know where a replacement can be ordered from? Thanks for the great info.
Old 05-09-2012, 06:50 PM
Subydude09's Avatar
Subydude09 Subydude09 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4x4 Crew
Rep:50
Subydude09 will become famous soon enough
Sadly, it must be ordered thru Dodge. My passenger side puddle lights went out recently. Same issue, water intrusion. The turn light still works, however to my dismay I cannot just replace the LED's, but rather the whole thing. Cost me $183!! And I still don't know how to get it out!
*Tow Hooks *LineX *Truxedo Bed Cover *SS Step Bars *HID's *Flowmaster 40 *35% Tint *Nightshades
