Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Warranty Issues
Dodge Ram Warranty Issues Discuss your Dodge Ram Warranty in this forum.
Old 04-23-2012, 12:40 AM
grifology's Avatar
grifology grifology is offline
Vehicle: 2012 dodge ram
Trim Level: sport
grifology is on a distinguished road
Default voiding a warranty
good evening... i know this has been asked before but i couldn't find it... will replacing the stock oem muffler with a louder flowmaster void the warranty and also installing hid's in the head and fog lights do the same???
(sidebar) got the hid's installed and whenever they switch on a light on the dash comes on then goes off after they completely turned on. meaning after they warm up and get the full glow... what is that???
please excuse my perfect imperfections....
Old 04-23-2012, 06:19 PM
heminit heminit is offline
Vehicle: 2003 Ram SBRC
Trim Level: SLT Sport
heminit is on a distinguished road
Replacing the muffler will not "void your warranty". You may loose warranty coverage for any component after the new muffler. If the lights you installed cause failures with wiring or other warranty covered parts the claim may be denied. The test will be 'did the failure occur as a direct result of the aftermarket part'.
Old 04-24-2012, 01:10 AM
grifology's Avatar
Trim Level: sport
thank you that's just what i needed to hear...
Old 04-24-2012, 05:33 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
The light that comes on on your dash is for the TMPS sensor. I have yet to hear of a Ram that does not do that. Weve pretty much chalked it up to the ballast creating interference with the radio signal from the sensors to the PCM when they first fire up. You not alone in that and eventually youll forget it happens
2011 Big Horn 4x4 -SnowWhite-
