Power Locks Not Working- Switch in Cab or Remote - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 08-02-2015, 02:46 PM
rlkellog rlkellog is offline
Vehicle: 2008 Dodge Ram 1500
Color: BLK
rlkellog is on a distinguished road
Default Power Locks Not Working- Switch in Cab or Remote
A few weeks ago my drivers side passenger power door lock stopped working. Before I had a chance to take off the panel and replace parts, the three other doors stopped working as well. Currently, none of the power door locks will work with the switch in the cab or on my key remote. The remote will activate the panic alarm and will make the door lock noise but power locks will not work. Any advice would be appreciated.
Thanks,
Ray.
Old 08-03-2015, 10:09 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Hi, Ray, and thanks for joining the RamforumZ. I encourage you to stop by the Newbie Checkin section and introduce yourself so other members and give you a proper how-do-ya-do.
You might want to see if you can get a switch and test it. Another issue may be that the 3rd gen uses the instrument cluster for the power door lock control. Start with the fuse, and if the fuse is good, see if a recycler has a switch that you can try out.
Old 08-07-2015, 04:11 PM
Color: BLK
Ok I will check out the newbie section and also try some of your suggestions. I also noticed that new lights on the dash do not produce a chime noise. For example I was low on gas the other day. Usually when the gas light comes on a chime would sound. However, this time there was no chime.
Old 08-08-2015, 01:27 AM
Rep:2968
Good deal, keep us updated.
Old 08-08-2015, 10:14 AM
namretsud's Avatar
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:273
namretsud is a jewel in the roughnamretsud is a jewel in the roughnamretsud is a jewel in the rough
For the back drivers door check the wiring from the door to door frame. Common place for broken wires. I would also check fuses.
Old 08-13-2015, 08:24 PM
Color: BLK
Any idea which fuses to start with?
Old 08-13-2015, 09:55 PM
Rep:2968
The cover should have the list of what fuse goes to what. But check them all, just because.
Old 03-30-2016, 11:36 AM
Dayooper Dayooper is offline
Vehicle: 2003 Ram 1500 QuaDCAB
Color: GREY
Dayooper is on a distinguished road
Did you ever resolve? I have a similar situation. In addition, on my quad cab, the door key cylinder does not unlock rest of the doors nor does the vehicle speed increase lock the doors
