Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Place your Ad Here!
Old 05-01-2012, 10:13 AM
99veesixxer 99veesixxer is offline
Vehicle: 2000 dodge magnum v6 S/C S/B
Color: maroon
99veesixxer is on a distinguished road
she was crusin at 55 and it died. thats all i got from the story. but anyway ive had some developements
she told me her tranny fluid was good. i checked it and it was a beautiful pungent pond brown...so i changed it out..(she told me it was ok on level and color) anyway. i changed it out and added new tranny fluid and bam, no more bucking but now its going all the way to redline before it shifts... any help??
Old 05-01-2012, 10:26 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
How many miles on the transmission? I've heard that if you don't regularly service the transmissions and then change the fluid way late it can cause shifting issues. I'm not really sure why. It happened on my ford as well, everything worked fine then at 200,000 miles I decided to change the transmission fluid and it would then shift from 1-3, skipping 2.
Hopefully someone else has better input...
Sean
Old 05-01-2012, 10:50 AM
Color: maroon
it has 90k miles on it....
Old 05-01-2012, 10:52 AM
Color: maroon
why i only drive manual in my mustang i will never own an auto unless im to old to shift! then ill get paddle shifters
Old 05-01-2012, 10:53 AM
snrusnak's Avatar
Rep:1388
I'd think it'd be ok with 90k miles...
Any engine lights?
Sean
Old 05-01-2012, 11:26 AM
Color: maroon
nope. ive had my code reader on it. ive pulled hoses off and such tryin to get it to throw a code but nothin
Old 05-01-2012, 01:10 PM
Ram Tough's Avatar
Ram Tough Ram Tough is offline
Vehicle: 1999 Dodge Ram 1500 Sport 4x4
Color: Primer Gray
Ram Tough is on a distinguished road
Default Shifts Delayed or Erratic (Shifts Harsh at Times)
This is from my manual I found from Daimler Chrysler 1999 thru 2001 this troubleshooting is from the 46RE transmission hope this helps.. good luck...
SHIFTS DELAYED OR
ERRATIC (SHIFTS ALSO
HARSH AT TIMES)
1. Fluid Level Low/High. 1. Correct fluid level and check for leaks if
low.
2. Fluid Filter Clogged. 2. Replace filter. If filter and fluid contained
clutch material or metal particles, an
overhaul may be necessary. Perform lube
flow test.
3. Throttle Linkage Mis-adjusted. 3. Adjust linkage as described in service
section.
4. Throttle Linkage Binding. 4. Check cable for binding. Check for return
to closed throttle at transmission.
5. Gearshift Linkage/Cable
Mis-adjusted.
5. Adjust linkage/cable as described in
service section.
6. Clutch or Servo Failure. 6. Remove valve body and air test clutch,
and band servo operation. Disassemble
and repair transmission as needed.
7. Governor Circuit Electrical Fault. 7. Test using DRBT scan tool and repair as
required.
8. Front Band Mis-adjusted. 8. Adjust band.
9. Pump Suction Passage Leak. 9. Check for excessive foam on dipstick
after normal driving. Check for loose pump
bolts, defective gasket. Replace pump
assembly if needed.
