Old 04-23-2012, 07:29 PM
Jhock2012's Avatar
Jhock2012 Jhock2012 is offline
Vehicle: 2001 Dodge Ram
Jhock2012 is on a distinguished road
Unhappy Help with installing Dual stereo in 2001 ram
So I just got this truck about a month ago. I took the Dual stereo out of the my dodge I sold and tried putting it in this one. I just cut the wires from the stock stereo and used crimps to hook the wires up. I got all the speakers right but I hooked the yellow which shows that its the constant on the stereo diagram to the red and white. But it says that the red coming from the truck is the switch. I don't see a red wire. The only ones left are an orange one and a yellow/black one. But when I hook the red one from the stereo to the orange one on the truck and the yellow to the red/white the lights on the buttons stay on whether the ignition is switched on or not. I really need some help I have been thinking about this for awhile and I just cant figure it out. Below is a picture of the wires left over after all the speakers are hooked up. The only ones coming from the stereo are the yellow one with the fuse in it and a red one.
Old 04-23-2012, 08:40 PM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500
Rep:86
SnoopyIsMyHero will become famous soon enough
Swap 'em. Put the red to the red\white and the yellow to the orange.
This would be a great time to pick up a inexpensive multi-meter and make a test light out of an old bulb, a couple of 18" wires and some alligator clips.
2001 2500 5.9 4x4. Stock except for exhaust
Old 04-24-2012, 01:38 AM
Jhock2012's Avatar
Ok.. So I forgot something. A big something. I was hooking it up to the pink not the orange which I forgot to mention. Heres what I found out....
Red with Red/White & Yellow with Pink- It works but the button stays on even if the truck is completely off.
Red with Pink & Yellow with Red/White- It works but presets reset after truck is shut off and is turned back on.
Red with Orange & Yellow with Red/White- Only buttons turn on.
Yellow with Orange & Red with Red/White- Doesn't work at all.
Old 04-24-2012, 09:27 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I'm thinking that the orange wire is for the illumination. If you don't bother hooking up the orange wire, then the lights on the radio won't dim when you turn on your headlights. Or if you do hook it up, find out which wire is the for the illumination from the truck harness.
I always buy the vehicle specific wiring harness when I change out a stereo system. It saves on confusion, and I'm able to wire everything up while sitting at a table, rather than bent over or under a console out in the vehicle.
What someone else suggested of getting a multi-meter is an excellent suggestion. You can pick one up pretty cheap (probably less than $10 but less than $20 for sure). This will allow you to be able to test if there is current on each wire, and when the current is flowing (i.e. ignition on/off etc).
good luck
Exco
Bill
Old 04-24-2012, 01:37 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
It would have been less agrivation to just buy install kit then it would have been plug and play. I had my sony done and buttened back up in 30 min.
Old 04-24-2012, 04:39 PM
Jhock2012's Avatar
I know that the red/white is the ignition and the pink is the constant. when i hooked it up like that the button lights on the radio stay on. I know for a fact i have it hooked up right. I'm just completely stumped on this.
Old 05-01-2012, 09:25 AM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:37
Pyroboy5000 is on a distinguished road
ouch. you never want to cut the factory stereo harness if possible. you want to find a wire harness adapter. it makes life so much easier.
I'm back from the dead!
R.I.P Old Blue 2013
Old 05-04-2012, 03:42 AM
Jhock2012's Avatar
I don't know.. I've always done it this way and this is the first time this has ever happened.
Old 05-04-2012, 12:34 PM
kylehite21 kylehite21 is offline
Vehicle: 2000 Dodge Ram 1500 5.9l 4x4
Trim Level: laramie SLT
kylehite21 is on a distinguished road
having the same problem, haha on my 2000 1500 bought a pioneer cant figure it out i hooked the red/white wire to the red in the new one and the pink to the yellow and nothin! tryed to reverse them still nothing
